in a car
thermostats open at around 85 C and are fully open around 95 C
the thermostat keeps opening and closing to adjust the coolant flow to maintain an operating temperature of around 87 C- 90 C
if you do not have numbers on the gauge slightly less that half a gauge to half a gauge
https://books.google.com/books?id=XNsDAAAAMBAJ
Vol. 115, No. 1 - Magazine
Right, plates of full depth and weight ... Loose hold-downs - bouncing arounddamages a battery several ways ... Excessive loads - using the starter to move thecar should be only a ... ask for a temperature-corrected hydrometer reading, which should be 1.260 specific gravity. ... All this is dependent on the individual car.
temp gauge bouncing around before going to center? ' Yahoo Answershttps://answers.yahoo.com/question/index?qid...Sep 28, 2013 - I called my mom and we switched cars and she didn't see anything ... Best Answer: If the temp gauge is literally "bouncing around" this is more ...Why is my temperature gauge jumping?Jan 1, 2013Temperature gauge bouncing.?Dec 18, 2008What does it mean, when my coolant temp needle jumps up and ...Oct 3, 2008My car temperature gauge keeps bouncing around from cool to red ...Dec 12, 2006More results from answers.yahoo.comTemperature Gauge Jumping Around an
Vehicle temperature gauges (temp gauge) read the temperature of the liquid in cooling system. From what I understand, the temp gauge jumping around has since gone away after you placed water into the radiator. It is very possible that water converted into steam was trapped in the cooling system and reached the temp sensor in your engine. The vehicle moving caused this steam to shift around reflecting rapid changes in temperature on the sensor, causing the needle to jump around on your console. Hope this helps.
Get an oven temperature gauge and place it in the oven, turn on the oven with the dial set at a near mid position letting oven stabilize in temperature. Read the temperature and mark the dial. Repeat at select positions marking the dial with the new temp setting.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe Appliance repairman colchester
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
