Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 50h13 projection tv
When I first turn on my tv, I get wavy lines across the whole screen. This started out just at the top 6 to 8 inches and has progressively gotten worse. It goes away after a few minutes but has gotten to be a longer few minutes with time also. Any advice in resolving this matter would be helpful. Thank you.
    Genius:
  • 1,694 Answers
Use cold freeze spray ( comes in a can ) on components while
set is hot and running----isolate the problem part or circuit board
before ordering or rebuilding anything.......T.
Posted on Oct 27, 2007
  • Vista Electronics Oct 27, 2007
    Squirt some cold freeze inside shield covering hyper board---
    Find a tech who is willing to change surface mount caps---
    It's tedious,but can be done....T.
  • 87 Answers
You have a bad hyper board part #23148024.  The part is NLA.  I have one in stock or you can have yours rebuilt at PTS Electronics 800-844-7871.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
Screen shuts off but power stays on then when unpluged for awhile comes back on also is wavy lines in the screen..
You need to replace both of the STK ICs they are big black ICs and will have PN# on them example STK392-110.
Mats Electronics Has ICs 1-800-628-1118
Feb 20, 2011 | Toshiba 50H13 50" Rear Projection...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42WH36P rear projection TV has wavy lines
the problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Dec 29, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Distorting
if it is wavy lines across the top it is probably the scan converter/ hyper bd they are becoming hard to find/expensive you can repair them but it requires many surface mounted capacitors and requires some VERY skilled soldering.
Apr 23, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
