Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Audio problems I can not heard anything, the audio device dissapeared after I installed Windows XP The Control Panel says there are not audio device
    Novelist:
    Scholar:
  • 167 Answers
There is a driver disk that accompanies your system. Install it and this should work fine. Here is how to install...if you want to not know.... Put the CD in the drive if you get an autorun screen click the appropriate icon [or just click the sound driver icon,if it is there]. If this did not work...try this; Right click the My computer - click properties - click hardware - device manager Then click the 'scan for hardware changes' icon.... if a new hardware found message is displayed, then click next and so on until you get it finished. Note; sometimes BIOS settings prevent audio devices from getting confugred automatically. so if the udio option is disabled in the BIOS setup you should enable it.
Posted on Oct 02, 2007
SOURCE:
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
My window xp lost the sounds
go control panel select audio device d click on it l click on audio watch the default device have like realteck or another .If there is no device re install the audio driver from mother board driver again.after install the driver the problem is same , should go BIOS enable the on board audio device if you use the inbuilt audio.
Nov 11, 2010 | Computers & Internet
Im using acer aspire 4520 with windows xp... i also tried alot of SO my problem is that audio device doesn't work... i install audio driver.. sometimes it works and sometimes don't so when i finally get it...
I would first try to check for viruses and spyware. This is one of the major causes of sound issues. If everything else is ok with this laptop, then it sounds like your audio card might have a problem. Howver you might also have a problem with your speakers. Try connecting external speakers to you computer. If they work then it's your speakers. You can purchase those online from Ebay.
Aug 04, 2010 | Acer Aspire 4520-5582 Notebook
Sound problems with Windows XP 2002
The very first thing we should do is to check whether the sound card is installed in your system.
To check open device manager. Here are steps to open device manager
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Double Click on Sound, video and game controller.
If you do not see Sound and audio controllers, then you have to install it,
Installation of Sound Card.
  • Select the Multimedia Controller or Sound and Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Browse Your Driver from the Hard Disk and click on next.
  • You can also install the drivers from CD.
Driver will be installed if the problem is still exist. Replace the sound card or have a local tech take a look at the sound card.
May 17, 2010 | Computers & Internet
Problem with on board sound L4s5mg/mx
If sure that you install with the driver of your audio built-in device, then it might have a sound already. How about to check your Audio setting in your BIOS Setup, see it there is ENABLE and run the Windows XP normally. If it is still not working then check in your Device Manager to see if your Sound Device is working. Good luck!
Jul 27, 2009 | EliteGroup L4S5MG Motherboard
My laptop brings out no sound
Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test.
If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed.
You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work.
You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Jun 03, 2009 | Acer Aspire 1642ZWLMi Notebook
No sound
Actually the problem is incorrect installation of Drivers.........so firstly uninstall the drivers from ur CONTROL PANEL and re-install it once again...........if the problem is same, then re-install the XP operating system sp2 with different CD serial and then drivers.....
CAUTION: see thst there is no virus exists in ur HARD DISK.......
Aug 18, 2008 | Microsoft Windows XP Professional
My sond card drivers is not available
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 17, 2008 | Microsoft Windows XP Professional With...
Sound and audio devices problem
all the options in sound and audio device properties are in active no sound is heard
Dec 17, 2007 | Edirol UA-4FX External Sound System
Computers & Internet Logo
52 people viewed this question
Top Linare Computers & Internet Experts
Ekse
Alun Cox
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
