Question about HP Compaq FS7600 17" CRT Monitor
Gauss? I'm not sure if I'm calling the problem the right thing. Every so often my image gets shaky and I have to use the buttons on the front to degauss it. This happens on at random times; at the worst times it happens up to every ten minutes other times it can go for hours without needing to be degaussed. Is there any simple way to fix this such as resetting it or something? I didn't put a magnet near my monitor but I think the problem was caused by either my new cell phone which was receiving data and sitting right underneath it the first time it messed up or it was might have been my laptop which was sitting next to it.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Yes you are right 1 what you can do in future is please do not move the monitor when you are doing work. 2 please do not use degauss button very often when ever you face problem if possible put monitor off for minimum 15 minutes.as degaussing is not that helpful when it is on. 3 as you know about magnet. 4 not but least crt is getting weak.( very rare.)
Posted on Oct 02, 2007
SOURCE:
Why does my Camera not respond to several of its buttons and the shaky icon is always on?
several things can cause this including a bad ribbon cable and a worn out button pad, or just a bad switch. Time for a tech to look at it. If you're feeling froggy, open it up and replace the button pad. Canon will send you another and may not even charge you.
Jul 25, 2014 | Canon PowerShot G11 Digital Camera
Hp 2010i monitor shaky, can't find degauss option
I don't think degaussing your monitor is going to help with this issue. Degaussing mainly addresses color correction around the monitor edges due to a magnetic field and applies to CRT monitors not LCD monitors which yours is. If by your term "shaky" you mean the image is unstable, then the problem is either in the main board which controls the X Y sync or with the power supply board. If you are knowledgeable with electronics you could probably repair this at home for $40 or less. If not then I would shop for another monitor to replace yours. Don't throw your old monitor away, instead post it for sale on craigslist. There are a lot of do it yourself type people who will buy this either for parts or to repair and resell. I don't know what it will bring as far as cash, might be $40 might be $5 but anything is better than zero.
May 09, 2013 | Computers & Internet
Wii screen is shaky
well try a different game and if it works without a shake then take the game to game sotp or the nintendo co. and if the other game does the same thing than take the wii to get fixed
Dec 22, 2012 | Nintendo Wii Console
Have a lincoln 2000, it's supper shaky and also has a noice not so sure wat could it be they tell me the coils
Please describe the 'super shaky' and the noise. The following might help.
Well, I'm not an expert but your description matches threeissues I have seen with my LSs (I'm on my second 2000 LS) and others I waslooking at buying. The immediate concern is that you say you have a noiseand I say DO NOT DRIVE THIS CAR ANY FURTHER! If the noise is kind of a whine,you may be okay for a while but if it's a high pitch and/or loud groaningnoise, STOP, get out of your car, get a flashlight, and check the ball jointsand/or the upper steering arms (I believe that's what Ford calls them). The LSlower ball joints and related upper steering arm that are, in my estimation,poorly protected with a CHEAP rubber protector that deteriorates anddisintegrates to nothing well before the life expectancy of the front endjoints they are supposed to protect. In any case, this would be a big concernso check this item first. Grab a flashlight and turn the wheels all theway, (best results = to the left for the d-side, right for the p-side) so youcan inspect the joints. That being said, "coilpacks" and/or faulty spark plugs are the most likely culprit for the"super shaky" if it's more like bucking and jerking and affecting duringacceleration or when you're cruising. Find yourself an auto store that withread your emission codes and look for a P030# code, wherein the # is thecylinder number (V8 motor). For example, a P0304 code means a misfire in the #4cylinder. BTW - the number 1 cylinder isthe front RIGHT (psngr-side) cylinder. The code gives you the cylinder number that is misfiring and it could bejust spark plugs as they generally last 75-115K miles.The other thing it could be is your transmissionslipping but I don't know anything about transmissions.
Jul 07, 2012 | 2000 Lincoln LS
Picture is shaking during live events
If its just live events, I'm going to assume its your cable/satellite provider. If you watch blu-ray, DVDs and it doesn't shake your TV is fine.
The first step is to determine whether it's the LCD display, the image or the video feed from your cable or satellite provider. Make sure all your connections are secure and not
To test the LCD display, open your menu options to see if that shakes. If it doesn't then it's not a hardware problem and your TV is fine.
If your menu does shake, unplug everything from the TV. You will need to test if you have possible inference from other devices. One by one plug your devices in and view the menu for it to start shaking. This is one possible solution to the shaky image.
Again, other possible solution is your cable or satellite providers feed is shaky. You need to call them and inform them of the issue. A replacement receiver could solve the issue.
Jan 07, 2011 | Televison & Video
I have kodak easy share z1275 camera, whenever i try to take a click of photo the screen shows friction or some thing like shaky images gets clicks, means the photo which gets clicked shows all blur...
Check your camera settings may be its on Night mode .Make sure you using the Auto ,Landscape ,Portrait etc..NIght mode can use with the help of Tripod.
Sep 27, 2010 | Kodak EasyShare Z1275 Digital Camera
Can't figure out how to adjust VCR tracking
Open the player, use cotton wool and methylated spirit to clean the play head of your tape player and the picture will be clear. It is dirt that is making the picture shaky.
Its not all the time that tracking can solve the problem. So clean the player's play head and all will be well.
Please don't apply too much spirit and make sure you dry it with a dry wool. Also make sure the player is turned off and removed from electricity before you proceed for the cleaning.
This is the help that I can render to you.
Good luck.
Apr 23, 2010 | Quasar VHQ401 VHS VCR
My canon powershot SX100 IS has image stabilizer, but apparently I'm not using it properly. All my pics, even stand still pics, turn out blurred. What am I doing wrong? My sons graduation pics were ruined,...
Image stabilizer (IS) will help you stabilize your shaky hand when photographing static object in dim light environment. When photographing moving things such as humans, camera IS will not and cannot not freeze them unless you use high shutter speed. If your camera allows high ISO and manual shutter speed setting, experiment indoors with it. Just remember, high shutter speed freezes motion and IS can only steady your shaky hand for so long. Tripod can only steady your camera not the subject if the subject is a human being.
Aug 18, 2009 | Canon PowerShot SX100 IS Digital Camera
Shaky image at particular are in canon 6650 photocopier
the scan lam assembly is dragging when you hit
print
If you can get access to the scan rails( remove the glass platen put small amount of silicone on the rails and if it moves manually(do not force )
If this does not work there may be a clutch or electrmagnetic drive that is slipping
either way it needs o be removed and cleaned
Dec 29, 2008 | Canon NP 6650II Copier
Shaky image on bottom of screen.
my guess is a capacitor is going or you convergence is going
you could send it into ptscorp.com
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
HP Compaq FS7600 17" CRT Monitor Logo
59 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
