Question about Dirt Devil Featherlight Bagless Upright Vacuum
Dirt Devil Featherlite Bagless Upright
This vacuum has great pickup but, it is so hard to push. Is there a problem with the automatic height adjust. I hate to take it back but, we can't even push it. thanks in advance jesse
Check the height adjust knob. It may be broken and need to be replaced. Turn over cleaner and move the knob from flat floor to plush crapet. If the two little wheels don't move, you need a new knob. Costs under three dollars at DirtDevil.com
Posted on Oct 10, 2009
    President:
  • 1,673 Answers
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
SOURCE:
HEIGHT ADJUSTMENT ON DIRT DEVIL UPRIGHT DOES NOT WORK AND I CANNOT VACUUM ITS HARD TO PUSH
The height adjuster may have failed. Best to turn the machine upside down and check operation.
Apr 22, 2017 | Dirt Devil Vacuums
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
Dirt Devil Featherlite Bagless Vacuum no suction
They do wear out and if you use it a lot that will happen. If you just bought it then i would return or call customer service
Apr 16, 2014 | Dirt Devil Featherlite Bagless Upright...
Very hard to push, the automatic height adjustment seems to be stuck in low postition
I'm growing tired of telling everyone what a piece of **** this vacuum is, I think you'll be the last! There is a design flaw that forces the wheels down according to how low you are holding the handle. Even when holding it at a normal operating height it is too low by design, causing difficult operation and finally multiple belt breaks! see my other posts about how to fix this, although it may not be worth your time!
Sep 22, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Apr 08, 2009 | Dirt Devil M085850 Featherlite Bagless...
Dirt Devil Featherlight Bagless Upright Vacuum Logo
1,453 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
