Fisher and Paykel - SmartFisher and Paykel - SmartDrive (9) Excellence 7.5 - Pump Blockage
Hi everybody, I am experiencing problems with this washing machines pump. I am pretty sure it is a pump blockage. How do I get to the pump to clean this? Are there any blueprints for the engine/internals of this machine? I am clueless. Thankyou
  • Anonymous Nov 04, 2007
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
  • 69 Answers
Without knowing your model, none one can suggest a solution
Posted on Oct 04, 2007
Hi there i got a fisher and paykel intuitive and i got a code 9 error.
Scroll down to fault code 9:
Jan 13, 2018 | The Computers & Internet
We have a Fisher and Paykel Excellence 7.5 SmartDrive 9. I think we lost wedding ring through it. Do these machines have a coin catcher in them somewhere?
have a look under the machine where the tub hose goes to the pump
the catcher is in that hose
the tub hose will go in the top and the pump hose in the side so that any items drop to the bottom and are not put through the pump impeller
Mar 16, 2017 | Fisher and Paykel Washing Machines
Smartdrive excellence
Check the lid magnetic reed switch for corrosion or swelling and continuity when lid is closed.
Aug 01, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at
Sep 08, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel smartdrive excellence 7.5
The pump has a thermal cut out fitted,
Pump must have over heated and cut power to machine.
Replace the pump to fix this problem.
Feb 04, 2012 | Fisher Washing Machines
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
F&P Smartdrive9, excellence 6.5Lt motor restriction
Tipped the washing machine over to tip out the washing and water, gave the thing a shake, hit some parts with a soft faced hammer adn she worked!
I think that process dislodged a blockage in the water pump...
Jul 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
F & P Smartdrive Excellence works fine until it reaches the rinse and then just makes whirring noise. I can't get it to spin either and it won't empty. Is there a way of at least draining it. Cheers...
Hi Kiri,
F&P mahcines are a little hard to drain as the drain hose comes out of the rear of the cabinet half way up.
You may have to use a small container and manually bucket it out.
The drain pump is more than likely blocked (seen this a lot on the F&P) and is accessable from the front panel or underneath the machine.
Repost if you need anymoe help!
Jun 17, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
835 people viewed this question
Top Washing Machines Experts
