Question about Motorola Mobility RAZR V3
My motorola v3x problem
I cant use my motorola v3x because my phone is always hung the menu is not functioning i cant text or call because its always hung i try to turn it off but when i turn it on its hung again.i cant text. the key pad not functioning.what should i do?
    Brigadier General:
  • 7,752 Answers
Have the flexcable replaced and also have the firmware reflashed.
Posted on Feb 15, 2008
SOURCE:
My V3x doesnt let me read text messages
I just had this problem, after pulling my hair out, then trying any solution i found on here nothing worked. <br />So i tried something myself i had a lot of messages in my out box so i started to delete them on bulk with multiple delete, after i had emptied the out box, miracle of miracles it worked i can no access my in box, about time too! <!-- from fixya rte -->
Mar 14, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How do i reformat my motorola razr v3x phone?
you know we are same problem.. the problem of you phone is flex cable try to change it
Sep 09, 2008 | Motorola Mobility RAZR V3x Cellular Phone
MOTOROLA V3X PROBLEM
If it's new take it back under warranty. It's a software problem. If it isnt under warranty, then you could reflash the phone.
May 01, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x
Try bootloader mode. Hold down the * and # key at the same time, then press the power key. (3 keys all together). You should get a bootloader menu. If you do, your phone can be saved. If not...
Apr 15, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola v3x
can i use my v3x phone as a webcam?
Dec 27, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Text problem
Check to see if you have an excessive amount of txt messages stored on your phone. If so, clear/delete messages off the phone. If this doesnt solve the problem, it could be a software problem.If it's under warranty, return the phone for servicing. If it's not under warranty, then reflash the phone with new software.
Dec 07, 2007 | Motorola Mobility RAZR V3x Cellular Phone
How do you change txting style?
Menu>Messages>Create Message>Options>Change Text Mode#>Secondary. thats how i change it on my one.
Nov 13, 2007 | Motorola Mobility RAZR V3x Cellular Phone
V3x hanging and slow menu options
hi, we have the same problem with the same motorola unit.. i've cause a lot of money looking for the solution on this problem & the best thing was i got a solution on it. 1st suggestion is look for a expert technician that will reformat your v3x then ask the tech to check your camera and the ribbon if there is a defect, 2nd, let the tech diagnos your phone to look for the correct problem of your phone.. This thing happen to me already & thanks for the great technician i got & he make my v3x unit as good as new again.. never stick to one technician, always ask the opinion of the another technician, this is the best thing i did..
Nov 11, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x cellular phone
have you tried this? make sure that if the other persons bluetooth is not permently turn on that they select 'find me' in the setup selection. settings - connectivity - bluetooth link - setup - find me. good luck
Feb 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
