SOURCE: panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
SOURCE: Panasonic CQ-C700U
Sorry, there's no way to repair the CD, if faulty. Try looking for a "reset" a VERY tiny hole somewhere behind the "door", on the face of the radio chassis...Using a paper clip end push into the tiny hole for a few seconds, ignition/radio on...If you can't find a reset...take it to a friendly local car stereo shop and ask them to diagnose the problem ($40).
Good Luck
SOURCE: I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Testimonial: "YOU GUYS ARE RIGHT ON! THANKS FOR YOUR HELP IT WAS GREAT >"
SOURCE: I need a wiring harness for a panasonic cq-c700u
Hi and thank you for using fixya:
For the wiring harness you can go to an electronic store and give the model of your radio they will tell you which one is it. Or try any online electronics retailer
thanks
good luck
Testimonial: "Thnxs it was very helpful. Will use this site again"
