Question about Nokia 3120 Cellular Phone
Can't deactivate headset
My phone is acting as if a headset is attached. There is a headphone icon on the display screen, however, I have never connected a headset to it. When I call someone or someone calls me I cannot hear anything, I can use the speaker to talk and hear. Everything els appears to working OK
  • Anonymous Mar 26, 2014
    how do i remove the headset icon?
  • 91 Answers
Did you check the connector on the bottom of your phone ? If theres any greenish stuff (oxidation) on the connectors/pins, there's your problem. This occurs if the connector has been exposed to moisture. If this is the case you can try to clean off as much as you can and it might correct the problem. But if this doesn´t work, the problem might be inside your phone. If you're up for it, you can take it apart yourself and try to clean the inside of your connector. If youre not up for it, or the connector is clean, take the phone down to your local service-center and have them take a look at it.
Posted on Oct 05, 2007
The diagnosis above proved to be accurate, however we didn't have to take apart the phone, a good blast with an air duster cleared the problem
An Air duster is a can of pressurised air used to clean IT equipment/keyboards
Posted on Oct 16, 2007
2 Suggested Answers
SOURCE:
Shinos
  • 22 Answers
SOURCE: My phone is a NOKIA and is acting as if a headset ...
Problem is on your Headphone Interface, go to nearest service centre and change that part. or clean that part
Posted on Jun 04, 2010
I dropped my phone now when people call they can't
  1. Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
  2. While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port: ts1630_01.jpg
    To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
  3. If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
  4. If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
May 30, 2010 | Apple iPhone Smartphone
Headphone symbol when answering the phone
Add the accessories to your profile which you are currently using. It will show you the icon of the accessory connected.
Aug 20, 2009 | Sanyo Katana SCP-6600 Cellular Phone
How to remove headphone icon from the display
I have encountered with the same problem with my Nokia 6630. This may happen if somehow your phone is damaged by water or your cell is experiancing a extermly humid environment. So do one of the following:
1. Switch off your cell. Remove battery and put it some time in direct sun light. If possible your headset jack facking sun face. You can also use your table lamp. Just bend it to cover phone.
2. You can also use your hair drier. Just blow the hot air towards your phone.
Jul 21, 2009 | Nokia Consumer Headset
What is process for on fm radio without headphone?
IT IS NOT POSSIBLE TO ON FM radio w/o head set as an headset acts as the recieving antenna for the transmitted radio signals from the radio station
Jul 21, 2009 | Nokia 3110 Cellular Phone
Allways showing headset icon
put the headphone jack in and pull it out
in and out several times and see if something is stuck
Jun 05, 2009 | Nokia 6300 Cellular Phone
Headset icon problem
Hey mayita,
If ur headset icon is not coming when u insert a headphone, it is due to non-supporting headphone or due to damaged headphone connector.
If u headset icon is continuously showing, it is also due to problem in ur headset connector. At this time, contact mobile technician.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN([email protected]/[email protected])
May 12, 2008 | Nokia N73 Cellular Phone
Heaset sign is on continouisly
the problem is that when you inserted headphone in mobile , its metal contacts get connected inside then you can see that headset icon appeared on screen but sometimes it stills appeared beacause that metal contacts get connected inside mobile if there is no headset also. so you have to replace that if it get problematic.
Aug 13, 2007 | Nokia 9300 Handheld
Nokia 3120 Cellular Phone Logo
376 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
