Question about 2wire 2700HG-B Router (2700HGB)
Ip address?? i am trying to forward a port and i need my routers ip address and i dont know where to find it.....
  • 432 Answers
Try 192.168.1.254. You can also ping the ip. Go to 'Start', Run", type in "cmd" without the quote marks. Now type in "ipconfig /all", and that will give you the ip address.
Posted on Oct 02, 2007
SOURCE:
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
HOW DO I GET TO MY SETTING i WANT TO CHANGE THE UPNP... FORWARD THE PORT... i TRIED TYPING THE 198....IN THE ADDRESS BLOCK....AND ALSO THE ROUTER STILL DID NOT COME UP
There should be an automated port forwarding setup where you dont need to type in any IPs, but only the port(s) you want forwarded. also, the local IP isnt 198... but 192.168.1.x
To do this setup you'll need to go to the router's default page which should be sometihng like 191.168.1.x, you'll find this IP either on the bottom of the router, or in the router's documentation. Just type in this IP in your browser's Address bar and find the Port Forwarding page. Consult the router's documentation if you cant find it.
Dec 21, 2010 | Belkin (F5D7230-4) Router (587009)
Port fording code for digital samsung tv
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Mar 25, 2010 | NetGear DG834G Router
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
I am using Belkin F5D7632ak4A. My problem is that:
In doing a port forwarding, you actually need to assign a manual address on the computer where you are using the service port for the computer not to change the IP address. If your private address on the network is 192.168.1.XX then you may assign on your computer 192.168.1.2-99 any of the address there. Also you may need to know the DNS you are using on the router which you can find on the status tab of the router.
To assign an IP address, if your computer is wired then right click on the wireless connection and select properties, if it is a wireless computer right click on the wireless connection and select properties.
After you have selected the said properties> look for Internet Protocol TCP/IP then select properties.
Then click on USE THE FOLLOWING IP ADDRESS and USE THE FOLLOWING DNS server as well.
then from there you can put in the set of address you have for ex.
IP address 192.168.1.10
subnet mask 255.255.255.0
Default gateway 192.168.1.1
DNS
preferred DNS 66.28.87.105
alternate DNS 66.28.87.104
Note: these are just example. after you have done assigning an IP address then you may do the port forwarding again. change the IP address on the port forwarding tab to the IP address you have assigned. Then don't forget to save the settings.
Jul 17, 2009 | Belkin (F5D7230-4) Router (587009)
Problem connecting with mates on fifa 09 on ps3.
here is the link for your port forwarding configuration:
http://kb.netgear.com/app/answers/detail/a_id/1166
here is the link for HOW IS PORT FORWARDING CONFIGURE:
http://kbserver.netgear.com/kb_web_files/n101145.asp
Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
To Let an Application Use Port Forwarding
  1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
  2. Enter the router's username and password.
  3. Under Advanced, click Port Forwarding on the left menu bar.
  4. A Port Forwarding Screen (Varies Slightly by Router)
  5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
  6. Enter the IP address of your local server in the Server IP Address box.
  7. Click Add.
  8. Click Logout to exit from router settings.
To Add a Service for These Routers
To define a service not in the Service Name list, determine what port numbers are used by the service.
  1. Click Add Custom Service.
  2. Enter the first port number in an unused Start Port box.
  3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
  4. Enter any name you choose for the service.
  5. Click Apply.
Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Port forwarding
What is the manufacturer of your router so I can get a user guide and taylor the instructions if needed?
Generally I would statically address the device to be forwarded to. If your router address is 192.168.1.1 and Subnet mask of 255.255.255.0 and it's DHCP server controls address 192.168.1.100 for 50 leases to 192.168.1.149 then consider using the range 192.168.1.2 - 192.168.1.99 uniquely as static IP addresses. There are more starting at 192.169.1.150 but let's ignore them for now. In the network adapter to recieve port forwarded content assign a static IP address based on the above as say 192.168.1.15 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1. The DNS addresses should also be static however depending on your router there may be an option. Some routers allow their address to be entered as the DNS address and pass requests as appropriate to the DNS servers loaded in their lan configurations, otherwise you will enter your ISP supplied DNS addresses into the network configuration.
Now that we have established a stable IP address to forward the port to we need to tell the router everything it sees for port 5060 gets forwarded to IP Address 192.168.1.15 port 8000. If detailed instructions are needed I will need to know the manufacturer and model of your router.
Please provide the additional information and any questions in a response to this problem and I will respond when available.
Dec 25, 2007 | Computers & Internet
Port forwording
ok port forward if any has router this is easy ill get too others in momment
routers port forwarding features type in ip address in internet explorer search bar at top
router ip's start like this 192. type the whole ip in
this will ask you for password and that usually is the word "password" or "admin" threw that you can set the router port forward by going down the list
now for comps with out routers
goto control panel
then network connections
right click on your connection
goto properties
goto advanced
goto settings
you will be directed to windows fire wall
goto exceptions add program or port you want to forward
basically port forwarding is a program that keeps 2 comps from having conflict with each other running the same program and helps in monitoring ports for intrussions
Dec 05, 2007 | Westell Wirespeed LiteLine 6100...
2wire 2700HG-B Router (2700HGB) Logo
181 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
