Question about Lexmark X83 All-In-One InkJet Printer
Lexmark x83 printer
I try to print and it gives the message "power short press power key" system error 000-v5.81 all the lights stay on when I press the power key -Photo,Normal and Quick lights. I have to unplug to get rid of lights as they stay on. What can I do?
  • krispiecreme Dec 15, 2007
    the power went out at my house for a couple minutes and now my x84-x85 printers 3 option lights are on(photo, normal,quick). The power button doesnt seem to work at all....i cant turn it on or off. if I unplug it and plug it back in, the only thing I get is an error message saying "error V5.81" I'm not sure what to do. Does anyone have any suggestions?? please help if you can
I have the same problem. >.<
Posted on May 14, 2008
SOURCE:
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
No printing
  1. Snap the cartridges in and out of the printer a couple of times.
  2. Clean the copper contacts with a dry cloth.
If this did not work then you need to give for service shop ,if they charge more than $50, you can buy new printer for the same charge..
Aug 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer problem
Hi I went to lexmark.com and they told me to unplug usb and power cord. wait 30 seconds. replug, press menu button until manitenance shows up and select. go to self test, select. it should print something. if not take out cartridges and redo steps. it did work for me
Feb 18, 2008 | Lexmark X83 All-In-One InkJet Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer does not connest to pc
I think "Cartridge short" is refering to a short circuit to the ink cartridges, remove them and clean the contacts, and try again, if this persists try replacing the cartridges
Aug 22, 2007 | Lexmark X85 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
195 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
