Tv Is not respondind
I have citizen TV Model #C24401,When I turn it on,I get power light On,but I m not getting any picture or sound.I is just dead
    Genius:
  • 1,139 Answers
This denotes a problem with the power supply either the low voltage power supply of the high voltage power supply. You will need the following documents and equipment if you plan on doing this yourself: 1) a schematic diagram 2) a Multimeter 3) an oscilloscope 4) a signal generator (color bar, cross hatch, and purity) The schematic will let you know where the test points are and the level of voltage and signal are supposed o be at the test point. The multimeter will allow you to trace and measure DC and AC voltages throughout the set. The oscilloscope will allow you to view the waveforms generated by the signal generator, this is needed to tell if a component is not processing the signal in the proper fashion. The signal generator creates a standard reference to measure by. Since this prolem is in the power supply section you should determine if the problem is a blown fuse by visually inspecting the fuse. Than you will need to determine if the problem is in the high voltage power supply. You do this by checking the transistors in the horizontal section of the TV. you will find the problem either in the low or high voltage power supplies.
Posted on Oct 10, 2007
SOURCE:
I have a 55 in HP TV and has power, when i press the on button the light turns blue but no picture THIS IS A FLAT SCREEN TV 55 IN.
get it fixed, call a service tech or take it in to a shop.
NO model TV stated at all just TV (HP)
HP LD5511 55"(this?) or some old plasma TV? what model is it , thanks.
on the rear is a tag that tag shows the model
first is age, how old is it and models tell me that.
the early LCD TV have back lamp that go out.
is sound dead, too? if yes, the TV has a bad internal power supply.
if sounds good but screen is dead, (use a flashlight pointed at the screen see video now (weak sure) but if seen that tells you the back lamps are burned out. (did TV screen run hot for many years )
yes, those are the ones that burn out.
here is the model prefix letter decode rules on HP TV.
  • PE or PL = Plasma TV
  • LC = LCD TV
  • LT = Professional Flat Panel LCD TVs
  • SL = MediaSmart LCD TV
  • MD or ID = Rear Projection Microdisplay TV
as you can see TV means Little. lacking full model numbers.
Sep 19, 2018 | HP Computers & Internet
Lg 42 no power
If its dead and no sound what so ever its usually the power board and if so you can usually get replacement boards by contacting the people over at
www.tvrepairworld.com if its not listed they most likely still have it and you can check by hitting the contact us button on their website and letting them know your model number and symptoms and a tech for your model will respond quickly to your problem for free as long as you include your model number and symptoms of the set.
Aug 04, 2012 | LG 42LC2D 42 in. LCD HDTV
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
Citizen TV model #JCTV3072
This is a very obscure set as there is nothing online about it! If the picture is rolling, that means it is an old tube set? Old technology, and not really worth trying to to do anything with it. Televisions never have an internal aerial. One the most basic table top with a 6" screen there is a pair of extending antennae and a coaxial cable socket.
I have edited your question to remove 'Hi There' and put in the television details in case any other of the Experts have come across this set.
Citizen TV JCTV3072 Google Search
Feb 18, 2018 | Citizen Televison & Video
Tv turns on the
Power converter board it dead.
Need to be replace.
Aug 15, 2009 | Mitsubishi VS-50609 50" Rear Projection...
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
Citizen house tv that has a 'lock' logo on screen
The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
Mar 10, 2008 | Televison & Video
KOLIN TV - Snap sound and went dead
The number is 1-888-796-8298,you need your model and serial number,tell them what happened and they will tell you where to take it.You should have some warranty.
Oct 03, 2006 | Olevia Kolin DLT2711M 27 in. LCD...
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
Ekse
