Question about Spotting Scopes
Tasco rifle scope 3-9
The elevation adjustment has broken loose allowing free movement.
  • 115 Answers
Re: Tasco rifle scope 3-9
This will need to go in for repair I would contact bushnell at 800-423-3537 option 1.
Posted on Oct 06, 2009
0 characters
3 Points
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
I bought a used scope with no manual. On the front of the scope it turns like the back but it has ranges on it do I need to know what range I am shooting for the rifle to be accurite
Take the bolt out of the rifle so you can sight down the barrel to the target. Get the target bullseye in the center of the barrel. Now look through the scope to see where it is. Adjust the windage and elevation screws to get the cross hairs on the bullseye. Look through the barrel several times to make sure the gun did not move off the target during the adjustments. A concrete bench with sandbags is best to use for this.
Dec 05, 2009 | Burris Fullfield II Riflescope
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Dwc3-9x40 scope
its real simple at the top and on the side of the middle of the scope you will find 2 knobs. unscrew the knobs and you will find 2 flat head screws one for each knob. one will say up with an arrow the other willsay right with an arrow. go to the gun range. set the rifle up on a bench ,fire, adjust the screws up or down left or right until the bullet and the crosshair matches one click of the screw will equal out to 1/4 of an inch adjustment. if you change ammobrands you need to do this will never be perfect but at 100 yards you should get 3 bullets in a 3 inch circle.
Nov 26, 2007 | Tasco Golden Antler 3 - (9 x 40 mm)...
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Spotting Scopes
Where to find manual or diagrams for Tasco scopes
The manual is here under "Generic Riflescopes". It is a .pdf file.
The Tasco site for Riflescopes
Oct 21, 2007 | Tasco Golden Antler 3 - (9 x 40 mm)...
Spotting Scopes Logo
143 people viewed this question
Top Spotting Scopes Experts
Michael Thomas
Michael Thomas
Are you a Spotting Scope Expert? Answer questions, earn points and help others
