The cd goes back to the first track again every time the engine is turned off. Is this normal for Scenic as my Espace one picks up where it left off the last time I used the car.
SOURCE: need radio code for renault scenic
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
SOURCE: i have bought a cd radio of an renault scenic from
POST A NEW QUESTION
quoting
the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or
A
Renault normally has a 14 character Serial Number beginning with
RN++++++++++++
plus a Security Code in the format TOX123 or TX123 or just X123 at the
end of a barcode ...so please quote EVERYTHING you can find.
Testimonial: "thanks very much - can move forward now"
SOURCE: Hi radio code
hope someone can help i need a service dealer who can read my EEPROM chip to get radio code, hope you can help.
SOURCE: how do i put my code back in to my renault megan scenic 1997 mod
= Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote
Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct
first digit
second digit
third digit
fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the
code
Testimonial: "that was great now working thnx"
SOURCE: I've had to replace the battery in my Renault
= Philips Renault Code Entry (For cars with a Steering Wheel Remote Control.)
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
press and hold the [ ¬] button for up to 10 seconds to store the code
