Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint built in dishwasher
My dishwasher will not drain. it will run the full cycle but be full of water at the end.
  • gemini2_1961 Oct 02, 2007
    I checked the air gap and it is not clogged. sorry. thanks anyway.
  • Anonymous Jan 10, 2008
    Just moved into rented house and not sure what means what on Hotpoint BF162, if I'm using correct cycle etc. Also, water doesn't drain. Single mum, not dumb, just rubbish with stuff like this. Help!!!!
    Took plug thingy out but nothing in there, all clean. Is there a drain cycle???
I just had the same problem with a Hotpoint 7810 plus , its been going strong for 20 years and its seems a shame to replace with a machine designed with 3-5 year obselesence. In my case the drain pump was blocked with small fragments of what looked like plastic but could have been limescale. Tools needed:-8mm Socket and nut runner(socket-screwdriver adapter) . ensure machine is empty but some water will be still in the salt dispenser so lay down towels/heavy blankets. Turn machine over onto front face, rotate through 90deg to place on its side, remove the base front panel 2 small pk screws gets access to drain pump area, unclip drain hose and pull off pipe from drain pump, unscrew 2 mounting screws holding drainpump , pull drain pump off of base unit, reove earth and to other power connectors (make a note of what connections go where. check to see if impellor can rotate or for obvious blockages. You can get a replacement drain pump for about £25-35 if it not a simple case of unblocking.
Posted on Mar 23, 2008
  • 114 Answers
Check your air gap on your kitchen sink. If equipped, you will most likely find it clogged. Pull off the metal cap, then unscrew the white or clear cap. You should find your clog there. Replace both caps and remember to pre-rinse the dishes better before loading.
Posted on Oct 02, 2007
  • Dave Harrison Oct 02, 2007
    Your drain valve solenoid could be defective. Drop the access panel at the bottom and you should see the solenoid directly in front of you. It will have two wires and a silver cylindrical plunger going into the center of it. Check for continuity between the two terminals. If it is open (no continuity) replace it.
Water not draining after last cycle
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
May 13, 2010 | Hotpoint 24 in. HDA3740G Built-in...
I would replace the drain pump as a first attempt at a fix. They're only around £15, and wear out first.
May 02, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher not draining. full of water after
You will have to lay the dishwasher on its back to access the PUMP
Jan 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Does not drain
take the front cover off and have a bucket and towels ready ,, remove the hose clamp off the drain line and remove it slowly to keep up with the water that will seep out of the line after it stops draining run water theu the drain and flush the system the take the hose off and run water thru it ,, out side,, then check if it goes into an air gap clear both sides of the air gap and all hoses,, if after doing all of this and it still won't drain, you will need to change the pump
Feb 26, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
311 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
