Question about Toshiba CF32F50 TV
White noise on screen with screeching sound
I have a CF32F50 TOSHIBA. i've been having trouble with the tv when i open it. It gives white unstable lines plus screeching noise. It comes down after 20 to 30 minutes then disapeares. But if i close it and reopen 10 to 15 later, i'll start all over again. Please help. Frustrated owner
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
White unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Posted on Oct 02, 2007
6ya staff
SOURCE:
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
My RCA Scenium HDLP50W151 TV makes is making a loud whining sound that varies in degree. I have picture and sound but the noise is beginning to drown out the TV volume
All projection TVs for RCA are DLP TVs, with that in mind these TVs have a lamp inside that produces white light. The color wheel is the one in charge of giving color to that light. Regularly the color wheel last between 2 to 5 years depending on the daily tv use. Most of the time when the central barring of the wheel is loose, unstable, or out of place it will cause the edge of the wheel to make contact with the housing, producing that whining, whirling, screeching or hissing sound. These sounds can either produce just a annoying sound when watching tv or can cause the tv to shut off. When this happens you’ll have to replace it, if you want to know where to buy, you can look in ebay, there are many parts you can get at very good bargains, the only thing is that you buy at a high risk of the part not working ( I had a bad experience). The other option is to buy at an electronics store online dedicated at selling tv parts, some can help you trouble shoot your problem and others may have tech support over the phone (personal recommendation: Discount-Merchant.com ). And last remember to search your part by part number, NOT by model number, two TVs with same model numbers but assembled on different dates ( different generation TVs ) will have none compatible tv parts inside, so be very carful.
Dec 24, 2009 | RCA Televison & Video
I have a Samsung HL85086W Made a screeching sound/no pic
All projection TVs for Samsungare DLP TVs, with that in mind these TVs have a lamp inside that produces whitelight. The color wheel is the one in charge of giving color to that light. Regularlythe color wheel last between 2 to 5 years depending on the daily tv use. Most ofthe time when the central barring of the wheel is loose, unstable, or out ofplace it will cause the edge of the wheel to make contact with the housing,producing that whining,whirling, screeching or hissing sound. These sounds can either produce just a annoyingsound when watching tv or can cause the tv to shut off. When this happens you’llhave to replace it, if you want to know where to buy, you can look in ebay,there are many parts you can get at very good bargains, the only thing is thatyou buy at a high risk of the part not working ( I had a bad experience). The otheroption is to buy at an electronics store online dedicated at selling tv parts,some can help you trouble shoot your problem and others may have tech support overthe phone (personal recommendation: Discount-Merchant.com ). And last rememberto search your part by part number, NOT by model number, two TVs with samemodel numbers but assembled on different dates ( different generation TVs )will have none compatible tv parts inside, so be very carful.
Nov 03, 2009 | Televison & Video
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
Toshiba cf32c50 tv will not turn on
This is a typical condition if the power supply has failed or a power-consuming circuit the supply services has exceeded a predetermined current draw. The relay you hear is preventing further damage or even fire.
You will need local tech help with this.
Sep 29, 2008 | Toshiba CF32F50 TV
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 29, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
425 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
