Question about Brother MFC 420CN All-In-One InkJet Printer
MFC-420CN scanner error
Printer is connected by Lan connection. When trying to scan either with the PC or directly on the printer I receive the following error message. "Unexpected data has been received. Please turn the device OFF and then turn it ON again. Then restart your PC and try the scan again.[TW004]" I have done this several times but still get the error.
  • Anonymous Nov 03, 2007
    My computer crashed, I got it fixed and now the printer does not work. I have tried to download it again but to no avail.
  • Anonymous Mar 01, 2008
    same problem
  • 832 Answers
This might be a hint: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000082/faq000182_001.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=8 another one is this: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=6&flang=English&dlid=
Posted on Oct 05, 2007
My cannon MG5220 printer will not scan but prints fine. i keep getting an error that says "cannot communicate with scanner for these reasons: -scanner is turned off. -scanner is disconnected (It is...
Many printers will not scan over a network, even when they are supposed to. Try connect to it with a standard USB cable and scan to PC directly. If that doesn't work - you have probably got a faulty scanner.
If the scanner works OK directly to a printer, then your issue is either LAN/WLAN bandwidth or an unstable IP address. Try fixing the IP Address rather than running DHCP address allocation eg set it at 192.168.x.150 where x is the range value for your network. Then set the printer port address on your devices to the same values and try again.
Nov 27, 2017 | Canon PIXMA MX870 Wireless Office...
Have a brothers mfc 420cn using windows
go to printers and faxes (where the printer is displayed). make sure the printer is turned on. you should see a place which indicates some thing like get pictures from scanner. click on it to scan. additionally open my computer to see if the printer scanner image is showing. you right click and select get pictures using wizard from the right click context menu.
good luck
Jul 04, 2010 | Brother MFC 420CN All-In-One InkJet...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
How to scan with brother mfc 7840w
Just put the scan job in the scanner and press the scan tab in your printer the scan image will appear in your directly connected machine/pc.
Oct 24, 2009 | Brother MFC 7840W Printer
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to scan
I encountered the same problem (prints but won't scan) over a network connection. A download from Brother got it working again. The filename is BrRegDev.EXE and it is available free at:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000037/faq000637_000.html?reg=us&prod=mfc7220_us_as&c=us&lang=en
If the link doesn't work, try searching for the filename using Google (for example).
XP Device Manager still lists "MFC-420CN LAN #2" (even though there has only ever been one), but at least it scans now.
Mar 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Osx 10.4 scanner
Have you tried a new driver? Did it work before? What program are you using to try your scanning?
Jun 22, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
1,297 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
