Motorola CLS 1410 (4 Channels) 2-Way Radio Logo
Wilson Horning Posted on Nov 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to remove front cover of cls1410.I removed four screws under battery.It still seeems to be secure towards top of unit.Screws somewhere I am missing?
John L radiodude365
Level 3:
Master:
  • Motorola Master 570 Answers
  • Posted on Nov 10, 2013
John L radiodude365
Motorola Master
Level 3:
Master:
Answers
570
Questions
0
Helped
209802
Points
1236
Yes, where the carry holder attaches to the radio. Pry the small plastic out and I am pretty sure there is another screw. I cannibalize a lot of these for parts because M will not sell parts. It is not designed for repair and can be hard.
1 Related Answer
Anonymous
  • Posted on Oct 03, 2007
SOURCE: need to disassemble
open the battery cover, unscrew the two screws towards the bottom. about mid-way up, there is a slot on either side of the radio under where the battery cover would have covered.. there are two tabs that need to be pressed outwards to release the middle. using a small screwdriver (or a blade) gently lift up the plastic display cover- it is only about the thickness of a dime so just barely get an edge and pry upwards.. this will reveal another two screws, unscrew those and you should be all set!
2answers
Mdg9700 need to remove front cover, which does NOT match normal maytag type bottom held by clips not screws, first look is that control panel needs to remove first but if so these are concealed.
The top panel and the control panel need to be removed first before the front panel can be removed. Once the top panel is off, the screws attaching the control panel to the dryer cabinet are exposed. The screws securing the front panel to the dryer cabinet are exposed once the control panel is removed.
Disconnect power and remove the two screws attaching the top panel to the rear of the dryer.
Slide the top panel towards the rear to clear the screw head from the flange at the bottom side of the top panel then lift it from the unit.
Remove the screws securing the Heater PCB Assembly at the left side of the dryer cabinet then flip the assembly over and disconnect the black and the white connectors from the board.
Remove the four screws attaching the control panel to the dryer cabinet then rotate it down and remove it from the dryer.
Remove the two screws in the door area and the four screws from the top of the front panel and attaching it to the dryer cabinet.
Pull the front panel forward then disconnect the interior light harness.
Lift the front panel off the tabs across the bottom and remove it from the dryer.
Reassemble the dryer in reverse order of the disassembly steps.
tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
4helpful
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
1helpful
One of the paddles in the dryer tumbler fell off. How hard is it to open the lid and screw them back on?
Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffle securing screws can now be re-tightened or reinstalled. Reinstall the top cover and the front panel by following the removal steps in reverse order.
9helpful
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
1helpful
Sounds like change is trapped in dryer makes a rattling noise? possibly trapped in one of the three rotating bars in the dryer drum. how can we get this out?
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and the screws securing the baffles. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
2answers
I cant open the mouse to get to the battery.
Hi
Please see the link it has a excellent guide
http://www.vk2k.com/Logitech-MX1000-Battery/
Please can i ask that you leave feedback and vote if this has been useful
3helpful
How to change out a broken lcd screen on an aspire
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
This is its contents without the pictures:
OK, let’s get inside the display assembly.
First of all, turn off the laptop, unplug AC adapter and remove the battery.
The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
Remove four screws found under seals.
Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
Carefully separate the display cover from the screen and access the LCD cable connector
You’ll have to unplug the LCD cable from the screen.
First, unglue the clear sticky tape securing the connection.
Second, unplug the LCD cable from the connector on the screen.
Here’s how you can remove the LCD screen.
Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
Now you can remove and replace the LCD screen with a new LCD screen.
Put all the screws back in there places
3helpful
How to take console cover off original xbox and clean laser
There are 6 torx screws located on the bottom of the unit. Four of them are under the rubber feet in the 4 corners and the other two are located under the stickers in the middle. Once you remove those the top cover should come off. Then look down on both sides of the cd rom towards the front and you will find 2 more torx screws. Remove these and you should be able to remove the drive. Disconnect the cables and remove the screws on the bottom of the drive. Clean the laser and you should be good to go.
3helpful
CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
