Question about Samsung YP-K3 MP3 Player
I lost manual, how can i put play lists on it?
I wanna put playlists on it, but i bought it from a friend who didn't have the manual. ???help???
Normanly you can't make playlists from your mp3 player, but if you make one on your computer and then add it to your mp3 you'll have your playlist.
Posted on Oct 01, 2007
What does sychronizing do?
Synchronizing on most mp3 players is used for transferring one or more playlists from a computer to the player, having a connection through USB.
Creating playlists, putting mp3 data in a list with a certain name,
mp3 could be put in a specific order.
The player preserves some space of memory to remember these playlists and the playing order.
Some players support subfolders, but not having the manual for the
MP200 I'm not sure if that will work.
e.g.
MUSIC > music list 1
> music list 2
Dec 20, 2009 | SanDisk Sansa e250 MP3 Player
Lost manuel for sylvania mp3 player smpk8854b
alright these are the controls
menu is select
the back button is the play button
if you wanna delete something use the fastforward and rewind buttons to go to explorer then select it
then press menu till you are in your music or voice folder or whatever u want to delete then press volume down and use the fastforward and rewind to select yes or no
If you wanna put it on hold press volume down and menu
and that should be it
Jul 09, 2009 | iLO MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Play listing
open your music player.
select playlist
select new playlist
type name of list
select folder that you want to play(click mark)
now click more option
select add
n enjoy
Jul 08, 2008 | Sony Ericsson K790i Cellular Phone
PLAYLIST CREATION
please install itune setup in u r PC after that connect the moto v3i with pc than create play list in itune play list. That play list click & drop u r mobile device.
Jul 01, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Slick mp3 player
When you try to play it the screen should say locked. Push the bottom button that says hold and the screen should say unlocked. Hope that helps. I just bought the same MP3 player and am liking it so far.
Dec 27, 2007 | Audio Players & Recorders
Can Download New Music
The "My Selections" playlist? You have to delete the entire playlist. Or do you just want to get rid of old music on it? It's a plug and play device (on XP at least) and you can delete what you don't want from there.
Aug 28, 2007 | RCA OPAL M4001 MP3 Player
Song problem (SanDisk 4gb
This is going to take some investigation on your part. First of all, make sure that the correct song works on your PC. That is, if you launch Don't Wanna Miss A Thing on your PC and Bout It plays, then it's the media file, not the Sansa player. Make sure you launch the specific media file from Windows, NOT from your media player software. You want to check the FILE first. (Reverse the files too - launch Bout It and see what plays) If the files are right, then launch them from your media player software. If they're wrong when you play them from the media player software, check the properties of the song. If everything is okay on the PC, then check the Sansa. If you are directly launching the music file on the Sansa (that is, not from a playlist) and it's wrong, then put the Sansa in MSC mode and check the file. Drag it to your PC and launch it. If it's wrong, replace it. If your launching the file from a playlist, just redo the playlist with the correct file after you've finished your troubleshooting.
Jul 12, 2007 | SanDisk Sansa e260 MP3 Player
Samsung YP-K3 MP3 Player Logo
80 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
