Question about Maytag Atlantis MAV6451 Top Load Washer
Drum full of water after wash
When wsh cycle is complete on my atlantis the drum is still full of water so we manually set to spin and then it drains and this is happening more frequently recently
  • lacydd Jan 21, 2008
    I've had my maytag repaired twice. It is about six years old. The drum is still full of water after washing a load of clothes. I've been setting it back to spin for about a year. Now it won't even agitate. It filled with water and won't do anything else.
  • 447 Answers
Lubricate the motor plate the whole motor slides back and forth to switch from spin to wash. Not a good design very problematic.
Posted on Oct 03, 2007
SOURCE:
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
The spin cycle does not work. The drum does not turn. The water drains out but doesn't go into the spin cycle to get rid of access water
sounds like a problem with your basket drive assembly brake release arm could be broken not releasing the brake allowing the basket to spin,,,,,
Mar 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Matyag Atlantis washer didn't drain
it could be a bad timer on the machine which tells it to change cycles i had the same problem and had to call them to come fix it. if this part is bad then it will go through asll cycles and never change cycles does that make sense?
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing cycles
if you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Sep 10, 2008 | Zanussi ZWF1440 Front Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
101 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
