Question about Hitachi 61SWX12B 61" Rear Projection Television
Sound problems Sound goes out periodically. Usually the problem is corrected when the tv is turned off, then turned back on. Sometimes the speakers will crackle and pop and the sound will return on its own. Any advice?
  • Anonymous Nov 16, 2007
    I am servicing one of this same symptom,don't beleive a speaker issue related.Found surround board intermittented.
  • kkiel Nov 23, 2007
    i have the same problem.
    snap, crackle, pop with no sound for minutes, hours and days.
    sound goes off mostly periodically
    Problem Solver:
  • 6 Answers
On this particular unit as well as some of the other RPTVs in this line from Hitachi, the sound boards seem to have known issues that aren't easily resolved, even with replacement boards.
Most folks resort to the use of an external receiver and speakers, which while it's not a solution for this particular problem, will at least provide you with a workaround...  -TD
Posted on Apr 30, 2008
I have same problem since we bought it, technician came in it worked sometime then problem recoocured, we lost internal sound, external worked with ext amplifier with external speaker.. didn't have time to call CONN's (where we bought the TV 61SWX12B....Any comments for what to do ???
REgards,
Posted on Dec 22, 2007
  • 790 Answers
You have defective speakers! you can repair your speaker change the spider suspension wire! thats why your speaker is crackle sounds!
Posted on Oct 01, 2007
Lost picture at first and now it appears to have lost sound also
Hi,lost picture - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling arepair man to replace the sound IC inside the TV.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
May 28, 2011 | Vizio 42 in. LCD TV
When I turn our tv on the power light comes on but the screen is still black and there is no sound.
Black Screen - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
May 25, 2011 | Televison & Video
Generic problem for all Flat Panel Televisions Plasma TV turns on
if I were you I would move the TV to a place where it would get more air to the vents of the TV so the heat buildup would be less.
Jan 10, 2010 | Maxent MX-42V1 42 in. Plasma Television
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
30" ASTAR LCD
Please call me 323-767-6030 and I will go through with you.
Oct 01, 2008 | Astar LTV-3001 Television
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Ge 46 inch projection tv
Turn your set on. While it is on unplug the power cord. Let it sit for about 5 minutes and then plug it back in. If the set comes on without turning it on you did not leave it unplugged long enough. If you you have to hit the power buttom to get the set to come on you will likely have sound. Sometimes you will have to go into the menu and turn your speakers back on. Also a satelitte reciever or cable bax can do the same thing. Usually you can unplug them for about 30 seconds and then plug them back in and turn them on to correct the problem if they are the cause.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Feb 01, 2008 | GE 46GW 948 46" Rear Projection Television
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Sound cuts out periodically
Sounds like a poor or cold solder connection in the sound circuit. If your not a tech, this repair really should not cost an arm and a leg to repair , but maybe your first born??LOLOL No really if you have no solid state repair experience please seek out a local repair person to assist you in this repair.
Sep 23, 2006 | Sanyo DS27820 27" TV
Hitachi 61SWX12B 61" Rear Projection Television Logo
366 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
