SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: i have samsung C3510 Genoa.
Enter this code in standby mode: *#52828378#
You will see "JAVA Test Menu" screen. Select option # 6 which is "OTA Test". Here you can see "Maximum JAR size (KB) which is 400 KB by default. Just enter your own value like 2048 KB. Press "Save" and exit from it. Now you can install JAR file of upto 2 MB size. Keep in mind that your new setting (2MB) will change back to default value (400 KB) if you RESTART your mobile. So, this is just a temporary setting but works perfectly to install large JAR files.
SOURCE: why my samsung galaxy s gt i9003 cell phone reeboot automatically
This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
SOURCE: how to unlock samsung galaxy y for free
hai, you can unlock your Samsung galaxy y by using unlock code. It is easy method don't need Google account to unlock it. you can unlock simply
1 - Switch ON your Samsung Galaxy Y S5360 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
you can get correct unlock code for your samsung galaxy y at TheUnlockArena.com
SOURCE: I can't open my samsung galaxy 5 due to over attempted of different patterns.
Wait for a minute, them retry the pattern.
