SOURCE: SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
SOURCE: Pioneer SD-P55A5 shut off during use and wont advance past standby mode
This is a problem related to the hue controlls in the TV. It is quite common.
Fix: You can go into the TV settings and try adjusting the hue/tint there.
If adjusting settings does not work, request help from a technician to fix it for you since it will take adjusting the hue internally and if you do not do it correctly it can damage your television.
I hope this helps ya!
SOURCE: 55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
SOURCE: Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
