In "system settings" there is an option to "Enable or disable WMA Playback". If it says "Enable" that means it is disabled and vice the versa. So yours should say disable as it should be enabled if you want to disable it. So just click on it. It should then change to "Enable" which means it is disabled. It is just as simple as a digital on/off switch. When it says "switch on", it means it is "off" and when it says "swith off", it means it is "on".
SOURCE: How to enable WMA playback
So you are having with the WMA Playback? (wireless network coverage may needed if you would to activate WMA Playback.):
Try this (for those that didn't have any wireless coverage and M33 CFW installed.):
1. Hold down the power off for 10 seconds.
2. Click [R] trigger at the right shoulder.
3. Keep it pressed, and turn on your PSP while you press it.
4. Go to registry hack>Enable WMA Playback.
5. Exit
Try this (for those that have wireless coverage and OE FW installed.):
1. Go to Settings>System Settings>Enable WMA Playback.
2. And you're successfully enabled your WMA Playback.
Any questions? Feel free to ask me =]
SOURCE: how to enable wma playback
what do you mean?, go to settings, system settings, then go to enable wma playback. and then what happens? BTW, you need internet connection to do this.
Hey I have found a link which is giving an info over disabling wma playback on playstation 3....check it out:
http://www.technologynectar.com/how-to-d...
Please respond whether its a working or not, or just something is missing..
