Question about Compaq Easy Access Smartcard Keyboard
Top Buttons on Keyboard not working
Buttons such as Connect, Search, Club Q, Calculator button. When pressed, none of these buttons will work
  • Anonymous May 28, 2008
    calculator button does not work
  • dlh1 May 28, 2008
    calculator button is not working
Go to your Start menu, Control Panel, then look for Keyboard.  Sometime keyboard is listed by itself, other times it is under another device name.  Click open keyboard, then click on the BUTTONS tab.  You will see 5 "buttons or selection options:  Calculator, E-Mail, Help, Search,Connect.  Mine does not open the Club Q button ...that's what I am searching for at this time.
Skip the calculator one (once the others enable, this one fixes itself for some reason. I went to the e-mail button first.  Double click it. Under choose a button capability: scroll down to the "Simple local file with label".  Then go to the bottom "ADRRESS" area, delete what is there and put in your favorite web based e-amail addree login address.  For yahoo.com it would be:  Http://login.yahoo.com ...yahoo will switch you to their secure server don't worry.  Do the same for any of te buttons you wish to change.
If the buttons do not show up at all, then you will need to upgrade your driver.  HP has an upgrade for its multimedia keyboard, I am sure you can google yours and find it, even if Windows cannot do so.
You have to have the Calcultor chosen on your Windows setup for it to work, but it just pops up after you update the other buttons.  If it doesn't. Its address on an XP os is:  something like: c (whatver your hardrive is located)://windows/system32/calc.exe ... thing is it can be different for different systems.
Now to figure out how to use that 6th button, the Q Club one?
Good luck.
Posted on Oct 18, 2007
SOURCE:
None of the numeric buttons work. the BIN button is highlighted at top and that appears to be the problem
That is normal: In binary numeration you only have two digits 0 and 1. Get the calculator out of BASE-n calculation mode.
Press [MODE] and select 0:COMP the general calculator mode.
Apr 17, 2011 | Casio fx-300ES Calculator
My top row of buttons on my dell keyboard is not working. the calculator button and other buttons? weird any ideas?
It says that the drivers for your keyboard is not installed...
you need to Install the drivers that came along with the Keyboard...
If it doesnt comes with a cd search in dell site and download the drivers...
This happens because, the default drivers for keyboard will be present in the database of windows, so you wont be facing any issues in using the keys...
But for using the special keys, u need to have drivers...
Dec 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
The buttons on my casio fx-9750g plus arent working
A simple procedure THAT MAY REVIVE the calculator is to reset the calculator by pressing the RESET button on the back. Use a straightened paper clip to press the recessed button.
Feb 25, 2010 | Casio FX-9750GPlus Calculator
My TI-84 Plus calculator won't work. It won't switch off by itself. When the batteries are reinserted, it says that all RAM has been cleared. When i press the 'ON' button again, the screen clears. but...
The Ram cleared message is normal after you change batteries. When you see this message you press the CLEAR button to erase it. You do not press the ON button again because the calculator is already ON. If you want to turn calculator OFF you press [2nd][ON] (OFF).
On certain calculators, pressing the ON button when calculator is already ON is interpreted as INTERRUPT the current command.
Jan 04, 2010 | Texas Instruments TI-84 Plus Calculator
Can't connect to pc,none everything right.only speakers working
you need to hold the button on the usb receiver until it starts to flash and then press the buttons on the bottom of the keyboard and then repeat for the mouse. this is done to resync so that they will work.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Feb 27, 2009 | Computers & Internet
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
None of my buttons work except the ON button
Sounds like a possible short to me, But I don't have experience with that cause I have yet to test my calc with water if you know what I mean... The one thing that I can suggest is trying to connect with another persons calc and try the "send OS" command to see if that will reset your calc to a working state. Sorry to hear about the damage though.
-Saik0Shinigami
Feb 06, 2008 | Texas Instruments TI-83 Plus Calculator
Compaq keyboard
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Nov 27, 2007 | Compaq Presario 5000 PC Desktop
Club Q button on the top of my multimedia model 5185 keyboard attached to mu Presario.
-Control Panel
-Keyboard
-Buttons Tab
-You should be able to reconfigure it from here.
Oct 18, 2007 | Compaq Easy Access Smartcard Keyboard
Compaq Easy Access Smartcard Keyboard Logo
2,941 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
