Question about Maxtor Hard Drive
Cpu /monitor when i start my computer the monitors shows memory etc then windows xp appears and colored green bars moving after a while it stop and nothing seen in my monitor
I start my computer and it works well but when it arrive at end of booting nothing appeared on screen, it shows me blue color .I do not know what i can do in order to boot my pc well
Posted on Sep 19, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Sounds like video card problem. Try removing, cleaning the gold contacts and re-installing to the slot. If your PC uses an on-board video that shares with the memory, then you have to remove your memory and clean the gold contacts then re-insert back and try again. If cleaning, re-inserting/re-seating does not solve the problem, then perhaps replacement is required. Hope this be of some help/idea. post back how things turned up or should you need further information. good luck and kind regards.
Posted on Oct 02, 2007
Monitor on karne ke bad kaise patachalega ki monitor ok hai or not ok
Disconnect the Monitor from the CPU.
If it goes thru a self test that means if you see the manufacturer logo or name moving on the screen or Color bars Red Blue and Green moving on the screen that means The monitor is working fine. If you don't see anything on the screen that means monitor is faulty.
Thanks and regards
Laxman / Fixya
Mar 27, 2016 | Cell Phones
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
Error before welcome screen, double picture in welcome screen, hang after welcomescreen
If your monitor is showing weird colors before the Windows XP welcome screen then it might be that your monitor is bad. Try hooking up a different monitor and see if the colors look fine as the computer is booting up, if it does then you know the original monitor is bad, if the colors still look weird then you know your video card is going bad.
As far as the lockups are concerned, with the computer turned off, take out the memory. With a can of air, blow some on the contacts of the memory and into the memory slots on the motherboard. You want to do this to make sure that there is no dust or dirt cause that can cause lockups to happen.
If you need more help, just let me know.
May 23, 2009 | XFX Computers & Internet
Monitor screens doesn't stop
It is a compatibility issue. If you plug the monitor/tv into the PC after you boot the PC it should show fine and not hange.
Jan 07, 2009 | LG Flatron L1718S LCD Monitor
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Shows nothing but cross horizontal bands
The monitor may not be able to handle the settings of the video adapter. If you boot into safe mode (tap F8 key as the computer starts), does the display appear correctly? If so, then you just need to turn down the settings (resolution, color quality, frequency) to the lowest possible settings. If the display still appears wrong, then it may be something wrong with the monitor. You can try connecting the monitor to another CPU and see if you can replicate the results.
Sep 14, 2006 | LG Studioworks 45 14" CRT Monitor
Maxtor Hard Drive Logo
184 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
