Question about Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player
Cd tray doors won't open
Motor comes on, if you smack they occasionally open. help!
I've had the same problem. Try leaving a disk in the trays when you shut it off... works great everytime now
Posted on Jan 31, 2008
  • 93 Answers
Check mechanics on CD door for dirt, or any loosen screws.
Posted on Oct 03, 2007
SOURCE:
Cd tray won’t open
In the good old days, a CD drive would always have a small hole in the front. To open the tray, you would straighten a paper clip and press a button about 1/2" inside the hole. This releases the latch and starts the tray coming out where you can grab it.
This video shows you how:
Jan 02, 2018 | Computers & Internet
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Tip
Xbox 360 tray stuck closed
This is a common problem with many older units.
When you press eject the light flashes on the box
and the screen says" Open tray" bu nothing happens.
The cause is a weak eject motor , that is unable to
break the magnetic seal holding the cd rom against the
spindle .
If you press eject wait 1 second then smack the top
of the box HARD right over the cd rom drive your tray will
open .
The fix for this is to clean out the drive and re-lube all the
tracks and guides ,also gap the magnet in the upper hub
so it holds the cd with a little less force .That will enable
the motor to break the seal with out stallingout
Rob
on Dec 02, 2009 | Microsoft Xbox 360 Console
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
Why Won"t the sliding door stay open long enough to insert the cd
There is a switch under the carriage that the tray should hit when it opens to stop the motor
Jun 09, 2014 | Audio Players & Recorders
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
CD tray does not open.
you need to change the motor belt charge of the tray
Jul 23, 2009 | Sony CMT-EP707 CD Shelf System
Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player Logo
775 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Andrew Taylor
Andrew Taylor
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
