Question about HP LC3040N 30 in. HD-Ready LCD Television
Screen goes bright after 1 hour of use
After an hour after turning on the LCD TV, it goes very bright, and the picture is not viewable. I turn off the TV, and turn it back on, and it's fine again for more than an hour before it does it again. Also the remote is not working. Put new batteries in, but to no avail. But it works occasionally when it wants to.
  • Anonymous Dec 15, 2007
    i have the same problem only my screen goes bright in a sec
  • woopdeedoo Jan 17, 2008
    I have the same problem. TV picture quality is excellent when first turned on. After 30 to 45 minutes, it begins to degrade. Seems to get brighter and brighter so that the images eventual become blurred and is basically unwatchable.
I have the same problem when switching component inputs. I also had a problem with the backlight going off after 10secs-5mins. Which is still being resolved.
Posted on Apr 19, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen problem
I have the same problem. rca 26lb30rqd. The red light is on (steady), and when I hit the power button, the blue light comes on for a second, then goes black, w/ no display. Before this happened, the display was extremely bright with ghosting. The picture was un-viewable. Did you every figure out the problem?
Mar 15, 2014 | RCA 26" LCD HDTV/DVD Combo 26LB30RQD - ON...
I have a 32" LCD
Tries tv turn off and turn on again about an hour later,see if the tv do resetting,tv might be back working to normal again.If still have the same problems.The tv have 1 or 2 long boards that call LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the LCD screen panel to produced a pictures.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
May 13, 2011 | Televison & Video
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
LCD TV Picture
I've seen some of these where some of the cable connectors inside of the set need to be reseated . They have become loose . Or you may have a problem in the video circuit of the set . Good luck
Feb 22, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
HP LC3040N 30 in. HD-Ready LCD Television Logo
184 people viewed this question
Top HP Televison & Video Experts
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
