Question about Sony KV-32FS13 TV
POWER 0N AND OFF
POWER TURNED ON FOR 3MIN. THEN OFF WITH VERTICAL LINE AND THEN BLINK 4 TIMES. WO'NT TURN ON AGAIN.
  • 790 Answers
You have defective vertical IC! the supply of Jungle IC is from the vertical output!
Posted on Oct 02, 2007
    Genius:
  • 1,694 Answers
Replace jungle IC. USE SONY IC.
Posted on Oct 01, 2007
  • Vista Electronics Oct 02, 2007
    On several Sony repairs in the last few months,
    the jungle was the culprit,not the vertical output IC..A high percentile of Sony vertical
    outs NEVER need changed,only hand soldering.
    Caution to techs==use cheap jungle only for test
    USE SONY PART # only, if,indeed the jungle is bad.Typical example===CXA2154AS found in FS,FV
    chassis and others.
    Note to BERTING---Please let me know how your
    repair works out.
  • Vista Electronics Oct 18, 2007
    Please upgrade my rating,if you feel it is deserved.Or let me know if you need further assistance.
SOURCE:
My Mitsubishi WS-65809 turns on and then off after 4 seconds. I have pressed the input/enter together and got 2 and then 4 blinks. What do I need to do to fix it?
First to be sure, unplug the set from power and then plug back--this clears the error buffer. Repeat the self check:
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
As you can see 2,4 is vertical problem----might want to remove speaker grill, inspection plate behind it and look up front--vertical is on middle board at right front as seen from front of set.
Look for ANY tiny drops of clear liquid which damages parts and is toxic-----glycol is what I would look for first.
Nov 04, 2012 | Mitsubishi WS-65809 65" Rear Projection...
GET DIAGNOSTIC CODES
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
Oct 29, 2012 | Mitsubishi WS-55511 55" Rear Projection...
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My tv power led red blink 4times
Blinking codes are never good news
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please r5ate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-R60XBR2 Television
Turns on for a couple seconds and immediately turns itself off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Let me know what you find and I will tell you what I know.
SD TECH
May 10, 2010 | Mitsubishi WT-42313 42" Rear Projection...
Will not turn on, red light blinks 4 times
In general when you have a blink of 4 times.
It indicates the Vertical deflection is stopped.
Symptoms of the problem: TV has entered the standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
To guide you in the right direction do provide details about your TV .
Hope this helps .
Jan 23, 2010 | Sony Televison & Video
Turns itself off after being turned on.
Here is what you do:
LET me know what you find and I will tell you what it means and if possible how to fix it.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 07, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Mitsubishi 55'' projection tv model # WS-55909 won't turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power on won't stay on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony KV-32FS13 TV Logo
248 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
