Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
No audio I transported my tv from my old house to my new home and when I turned the tv on there was no audio. I ckecked all the connections and made sure the mute button is off and checked with the Audio settings and everything seems to be ok, but no audio comes out of the tv. Thanks for the support.
  • 979 Answers
What type of sources might you be using, and do you use the RF input for anything?...accordianman
Posted on Feb 27, 2008
I moved my TV from my old house to my new house. Before it worked just fine at my old house, brought it to my new house and it just doesn't turn on! Tried different outlets, wires, etc.
Check the power at the plug point. Check the plug of the TV. If there is no life, then you will need to open the TV panel and check for a blown fuse, a circuit break while transporting, a loose connector within the set or a possible damaged SMPS>
check this link below for some tips on the power supply:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
My 15 year old Home theater RCA tv turns pink with diagonal white lines after 15 minutes
Are you using a component video cable to feed into the TV? If so... your cable may be bad. If you have different video outputs from the home theater system then use one of them such as a yellow composite video or S Video (round with multiple pins) . However, the fact that it's happening after a period of time suggests that something electronic is about to go. If you have another TV in the house to connect the system to then go ahead and do that. If it works fine on another tv then you have a problem with your old tv.
Feb 06, 2010 | RCA RT2380 Home Theatre System System
Cool down period for plasma TV for transport.
I believe 20 minutest just enough. But when you bring it back from cold outside to your new home it have to stay/warm 2-3 hours before you plug it in.
Dec 18, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Need to connect some samsung audio/video components
I'm guessing that you would like all your components to play audio through the HTZ320. In order to get audio from all these components you will need a digital optical cable from the tv optical out to the HTZ320 optical input. And some composit audio cables (red and white) from tv audio out to the HTZ320 aux input. The video and audio from the dish box, bluray, and the vcr are all going to have to go through the tv first and then to the HTZ320. Use HDMI cables to connect the dish box and the bluray to the tv inputs and composit cables (red white and yellow) from the vcr output to the tv input. If you can give the exact model of the tv I can help you sort things out further. I hope this helps you.
Aug 27, 2009 | Samsung Audio Players & Recorders
Audio, but no picture.
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Feb 09, 2009 | TruTech PLV16260 Television
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Jul 16, 2008 | Vizio P4221 Television
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
