Question about SanDisk Sansa E280 MP3 Player
Photo Size Does anybody know how I get my photos to display as full screen size - I thought the e280 sized photos automatically but mine are only about half the size of the screen, although they are large high-res images. Apart from this minor problem I think this MP3 player is great!
  • 8,596 Answers
No way to alter - function of the player. Relatively speaking, this player is not great
Posted on May 26, 2008
SOURCE:
I can no longer upload my photos. What is going on?
JigZone Photo Upload accepts pictures of JPG and GIF formats only. All puzzle pictures are a fixed dimension, 400 pixels wide by 300 pixels high:All puzzle pictures are stored with a maximum file size of 20KB (20,480 bytes). Photos which have a file size greater than 20KB will be automatically compressed, which could result in a loss of picture quality. For fast uploading and maximum picture quality, we recommend that your edit your pictures to be 400 pixels wide by 300 pixels high and have a file size no greater than 20KB before uploading them.Note: GIF type images cannot be automatically re-sized and must be formatted to 400 x 300 and less than 20KB before being uploaded.To limit the bandwidth costs of this free service, at this time the file size of a photo upload is limited to 2M or 2,097,152 bytes. Large sized photos could take several minutes to upload. During this time the upload page will remain on the screen.
Mar 26, 2015 | jigzone.com
PHOTOS CANNOT BE DISPLAYED FOR PRINTING
check the supported image size and file extension of the photo. it is possible that you got a larger orientation on the size of your photo.
let me know
Sep 10, 2008 | Kodak EasyShare 12.0-Megapixel Digital...
I can't seem to print passport size photo on my mg6120
well depending on what program you are using to edit your photo. I know Photoshop has rulers on the top and sides of the screen so you could adjust you size that way. Or you can (in photoshop) select and preset the size you want the image to be and then open the photo, then drag and drop photo to the preset sized screen and the adjust photo to fit in the preset space.
Some other programs have adjustments to images in the top left of the screen and will say things like "crop" or "re-size" try using those tools, I know in most Windows running computers you have PAINT already installed. And the re-size tool should work for you. I will show by percent % how much you would like to re-size your image. so if you want it have the size of what you already have then type in 50% in the horizontal and 50% in the vertical and then apply and see if that's the size you need. if not then re-size again (but remember one you go 50% (or half size) you will most likely not want to go that much the next time because it will be re sizing your already 50% and then reducing that size by another 50% so 2nd and 3rd try i would go 80 or 90% each time until you have reached your size.
I could go on and on but see if that works if not let me know and i'll give ya some more options
Sep 16, 2014 | Canon Pixma Mg6120 Wireless Inkjet Photo...
Large pictures don't display
Many digital photo viewers can only display photos of a certain size or less. Check your owner's manual, or find the manual online, and it should tell you what the upper size limit is for your viewer.
Jul 04, 2014 | Kodak Digital Photo Viewer
I have a datatraveler 4gb stick how many photo will it hold
That is not exactly to calculate. It depends on the stored image sizeand quality.
Small pictures could be 400KB a piece, but large ones easily can go up to 6GB
a piece. If you know thye avaerage size of your pictures, you can calculate it.
Aug 28, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
I take photos but display in the computer photo size is post card size, how to make little big picture
The size of a picture/photo depends on the resolution that you have set on the photo capturing source(webcam, Digicam etc). So you need to increase the resolution as much as possible to increase the size and quality on the photo. It will also increase the space required to store it.
Hope this will help.....cheers:)
Jan 02, 2011 | Computers & Internet
Wallpaper picture
Chances are that your camera is not set at the right picture size. To change it to the right setting, do the following:
-camera
-take a photo
-options
-camera settings
-photo settings
-change the size to 1024 x 768
When you set your new photos to be your wallpaper, they should take up the whole screen. Hope this works!
Regards
Katherine
Jan 16, 2008 | Lands Phones
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
