Question about Frigidaire FGF326AS Gas Kitchen Range
Gas Range I have A Frigidaire Gas Range Model# FGF326AS It will light and get hot but then the temperature starts dropping and you can smell gas. I don't smell gas when the stove top is used. Any idea what is wrong? Any info would be appreciated! Thanks, Nana
  • rob8up Sep 07, 2008
    The temp. is incorrect on the oven. all things take longer than they should. cookies, turkey etc.....
    Ignitor? or thermostat
    Thanks, rob
  • 473 Answers
Sounds like the ignitor is weak. I would replace the ignitor if is 3 yrs. old or more.
Posted on Oct 05, 2007
SOURCE:
I turn the oven and it gets warm but not hot and I smell gas
Warranty Information
Contact information
800•944•9044
Electrolux Home Products North America
P.O. Box 212378
Augusta, GA 30917
- WHAT TO DO IF YOU SMELL GAS:
• Do not try to light any appliance.
• Do not touch any electrical switch; do not use any
phone in your building.
• Immediately call your gas supplier from a
neighbor's phone. Follow the gas supplier's
instructions.
• If you cannot reach your gas supplier, call the fire
department.
- Installation and service must be performed by a
qualified installer, servicer or the gas supplier.
Dec 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Problem with the Frigidaire FGF326AS Gas Kitchen Range will not ignite
A few of the more promising DIY guides to helping you fix your igniter problem:
www.applianceaid.com/gas.html
www.davesrepair.com/DIYhelp/DIYovenignitors.htm
www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx
Dec 27, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Top burners on Frigidaire gas stove come on but the oven will not.Whats the problem?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Smell gas from inside oven. oven will not heat up. no leaks from gas line outside of oven
On the bottom of the oven on the inside you will find an igniting bar. It is rectangular and usually just has one or two screws in it. This is your problem, switch it out and it will work fine.
Aug 09, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Dec 20, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire Gas Range with paint blistering around largest burner etc.
go back to where you got it from the paint should not come off after such a short time same as the grates .
Oct 11, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Frigidaire FGF326AS Gas Kitchen Range Logo
177 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
