Question about Goodman GMS90703BXA Heater
Forced air fan
Sometime when my airconditioner is running, the little fan will come on and my blower motor will stop for about five seconds, I have not been able to tell if it turns my condensing unit off or not , after the little fan quits the blower motor comes back on
  • 42 Answers
You might have a sensor issue where it thinks it's too hot and kicks on the gas exhaust fan.
Posted on Nov 10, 2007
Whey does my fan stay on all the time on my chevy Cruze 2012
It will if you have airconditioner on.but should turn off after car is shut off and cools down.
May 17, 2017 | Cars & Trucks
AC blows cold air, fans stop blowing
I think you have a "variable speed resistor" problem, it's overheating. It's an electronic device usually located near or attached to the AC motor blower that controls the fan speed. This is a common problem with aging AC blowers with electronic controls.
Apr 13, 2014 | 2001 Pontiac Sunfire
Air handler blower fan doesn't blow. It does jerk a little every half-second or so.
When it tries to come on give it a spin with something safe (not your hand). If it takes off and runs replace the capacitor. It may just be missing the initial boost it needs to take off from a dead stop. That"s the capacitor's job.
Nov 27, 2013 | Rheem Ruud 51-24272-01 Blower Motor HVAC...
Air Conditioner fan not blowing
You may need to replace the reostat in the heater box. Do you have the hi speed only? Only have off and I, then it is definitely that switch in your box. You can easily replace it.
Nov 14, 2017 | 2006 Dodge Ram 2500
Heater and airconditioner control on mercery grand marquis
If the fan will not run on ANY speed in your Grand Marquis, the problem is most likely NOT the control switch.
Check for power and ground at the blower motor connector. If power and ground is present, replace the blower motor. Otherwise, the problem is most likely a failed blower speed control module (VERY common). The blower motor speed controller is located in the A/C evaporator housing just below the heater hoses.
Note: It is also common for a bad blower motor to CAUSE the controller to go bad. You MAY have to replace BOTH.
May 17, 2012 | 2001 Mercury Grand Marquis
My blower stop working on my 1992 buickroadmaster so it was replaced it , it worked for a little while and then it stopped working again.
Could have a bad relay for the blower motor. Sometimes shops will replace both the blower fan and the relay(s) together when repairing this problem.
Dec 18, 2010 | 1992 Buick Roadmaster
Ok, may sound like a dumb question,but how do you know if its a blower motor resistor problem or just the blower/motor. Ive been reading solutions for problem on the A/C blower still blowing air but speeds...
The blower motor resistor is usually only switched into the circuit for the lower speeds and for the fastest speed the resistor is bypassed so I guess the motor needs to be replaced if it does not work in any position. However, sometimes the blower motor is not protected by a fuse but by an automatically resetting sealed circuit breaker usually located not far from the motor. The circuit breakers dont fail very often, If the fan works for a few seconds and then stops and then does the same thing several minutes later then the fan motor definitely needs replacing.
Aug 21, 2010 | 2006 Nissan Altima
My 2002 gmc serra has a issue with the ac and heater the lights turn on but no air I hit a bump and it will turn on for a second but it stop blowing air cold or hot what could it be....
the blower motor resistor relay are bad about shorting out and melting the connector causing a loose connection and when you hit it or a bump it'll make connection and work. look under the passenger side dash and you'll see two wires coming from the blower motor. trace those two wires to a little black box with somemore wires pluged into it and try to unplug the other connector that has about five wires coming from it. turn your key on and your a/c with the blower speed set on high, try moving those five wires if the fan blows and quits, then this is the problem. you'll have to replace the resistor and the wire connector.
Jun 01, 2010 | 2002 GMC Sierra 2500HD
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Goodman GMS90703BXA Heater Logo
104 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
