Question about IBM ThinkPad T22 2647 Notebook
CPU Upgrade Help
Hi I want to upgrade my T20 and T22 with a P3 1.0GHz CPU but i don't know which Socket it has. I have found such a P3 that i want to Buy but it says is for Sockel 478 Laptops, would it fit on my IBM's? Thank you!
  • 432 Answers
Re: CPU Upgrade Help - IBM ThinkPad T22 2647 Notebook PC Laptops
I'm pretty sure it's socket 370.
Posted on Oct 02, 2007
0 characters
3 Points
Can we upgrade my laptop samsung 300v4z to i3 prossessor
No, You can look at your Motherboards specs and usually it will give you the CPU options. If you have never changed a CPU before it takes a bit of research as to what is compatible with your system/Motherboard. The specs I found say you have a Pentium Dual-Core B950 3.4GHz., not to shabby, and a different socket . I don't see the amount of DDR3 Memory you have, but that would be a easy upgrade.
Dec 03, 2012 | Samsung Galaxy PC Laptops
I am wanting to upgrade the cpu to a faster
You dont need to know your southbridge info or anything like that, you just need to know the socket type for the processor. If they make a processor for the socket type, then you can assume it is compatible.
Jul 17, 2009 | Toshiba Satellite M45-S331 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
PII Processor Upgrade?
well..the cpu and the board level chips are all designed to work together. i had a tecra for a while(gave it to my son) and I do not recall the cpu being upgradable
Oct 09, 2008 | Toshiba Tecra 8000 Notebook
Ibm thinkpad 2647
Your limited with the T20 series, the biggest you can go is 1ghz. Try the Pentium M chip, make sure that it's the same mhz (frequency) that's in it now, the board frequency matches the processor frequency. (either a 100 mhz or 133 mhz, you can tell by what memory it uses PC100 or PC133)
Jun 09, 2008 | IBM ThinkPad T22 2647 Notebook
Cpu upgrade
To upgrade the cpu, you will still need to use the same type of cpu. A socket 478 motherboard will not work with a socket 775 processor. The pin configuration is different.
Dec 21, 2007 | Toshiba Satellite A105-S4004 Notebook
Cpu upgrade for zv6000
Most of the newer processors use a different socket.
The Socket 939 chips go up to an Athlon 64 X2 4400+.
However: keep in mind that your computer's bios may not be setup to use newer CPU's. The only way to tell is to check compaq's web site for updates or just to buy a CPU and try it.
Dec 03, 2007 | IBM ThinkPad T22 2647 Notebook
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Ram Upgrade T20 and T22
hi you can try also i can order your ram and send it to you with a warranty I own a repair shop let me know what you want to do try
Oct 01, 2007 | IBM ThinkPad T22 2647 Notebook
CPU Upgrade
I think its an intel P3 socket 370.
IBM ThinkPad T22 2647 Notebook Logo
169 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
