Upgrading AMD cpu
I need help in finding what AMD chip is compatible with my ASUS motherboard. Already contacted ASUS and AMD....not alot of help with them!!! ASUS mb model-M2NC51-AR. My AMD chip is ATHALON 64x2 3800+ and I want to upgrade to no more than a 5200+, due to mb wattage restrictions (65 watt max). I am currently running Vista Premium 32bit, but will be getting the 64bit full version soon.
  • TATFROG Oct 02, 2007
    Thanks for the KICK ASS HELP!! But now that you mentioned vid card...how about some ideas to get me on the correct path!! (And I will probably need a short bracket for the card, since I own a Slimline). Once again....THANK YOU VERY MUCH!!
  • 21 Answers
There's two versions of the 5200+, one rated at 89 watts, and the other rated at 65 watts. 89 watt version: ADA5200CSBOX or ADA5200IAA6CS, F2 stepping, 1.30V/1.35V 65 watt version: ADO5200CZBOX or ADO5200IAA6CZ, F3 stepping, 1.20V/1.25V Make sure it starts with ADO, not ADA. There's still a lot of the 89W version in the channel, and not many of the new one. NewEgg currently has the F2 (89W) stepping in-stock for $124, and the model you want will likely be priced similarly, when available. They currently have (in-stock) a 5000+ for $120, that is 65W. If you want it ASAP, go with the 5000+ (ADO5000DDBOX). I would recommend getting the retail-box version, which comes with a new heatsink/fan and warranty; this assures you that the heatsink/fan is an appropriate match for the CPU. Note, depending on what RAM you have installed, this may bottleneck the CPU. For full potential, make sure you're running DDR2 PC-5300 (667mhz) memory. You should be able to get a 2GB "dual-channel kit" (matched pair of 1GB sticks) for around $60-70. Definitely run at least 2GB total for Vista; unfortunately, your motherboard cannot go past 2GB. Similarly, you may want to get a new video card (PCI Express x16), but don't bother going all out here.. the system will never realize the full potential. I would target $100-150 for a video card.
Posted on Oct 02, 2007
Compatibility of Athlon CPU and ASUS Motherboard
Yes it will work just fine. Just download and update your Bios to the latest version which is the 1007 release and you should be good to go. You can get the latest Bios here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/sis741GX/A7S8XMX07.zip
Jul 12, 2012 | Computers & Internet
I currently have a Asus Motherboard, 600W and a AMD Dual Core, 2.4ghz CPU. I would like to upgrade the processor chip but as I don't have the motherboard manual I don't know what kind of upgrade I can...
What you need here is the socket type of your CPU. To find that we need the model number of the chip, which can (hopefully) be found by opening the control panel, then going to Hardware and Sound, then to the device manager. Look under the heading for Processors. If you google whatever name is there, you should be able to find a listing that tells which socket it uses. If that fails and your computer isn't a custom, you should be able to search for your model number and find some system specs online. Any other CPU that fits in the same socket will work. All of those CPUs will also be made by AMD.
Feb 28, 2011 | ASUSTeK COMPUTER - RPS 600W 2+1...
What is the best available compatible chip for ASUS A8V-E SE?
Go to the Asus website. www.asus.com. Click on the support link. Lookup your specific motherboard model #. Once you have located this there will be a menu in the left hand side that will say cpu support. Click on this & it will list all cpu's that are compatible with your board and what bios version you would need to run with each cpu. Hope this helps.
Jul 12, 2009 | ASUS A8V-E SE Motherboard
Compatible AMD cpu
According to what I have found, this is an Intel Motherboard. You will not find an AMD chip to fit this. This is a socket 478 mobo. Heres the specs site: http://www.motherboard.cz/mb/matsonic/MS9367E.htm
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 04, 2009 | Matsonic MS9367E Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Finding a compatible motherboard and processor
The DDR1 is now Obsolete. I suggest you to purchase entire motherboard with processor, RAM and graphics card. As it is one time investment, try purchasing Quad-Core CPU's with atleast 4GB of RAM.
Feb 15, 2009 | ASUS A7S333 Motherboard
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Upgrading processor to Duron 1.4GHz
well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
also make sure the motherboard can actully take a higher processor.
Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 04, 2008 | ASUS VIA KT133A Chipset A7V133-C...
Compatibility
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
Computers & Internet Logo
663 people viewed this question
Alun Cox
David Payne
David Payne
