Question about Balance CN6555 Notebook
Balance CN6555 keyboard Problem
The first row of keys (Q-P except T,Y,P) Do NOT work. All other keys are functional. Question is, is there a keyboard replacement for this model?
  • delv Oct 07, 2007
    Hazer how can I contact you? Email, phone #?I tried taking apart my laptop and took a look at the keyboard connector but didn't go any further because I don't want to end up messing it up. So can you please give me a quote for the keyboard replacement ASAP please?
Yes there is a replacement you can buy i live in the uk and had two sent over via a friend in the states because they dont ship outside the usa, they cost about $13 each from the company in california i dont have there address at the moment
truker
Posted on Nov 16, 2007
  • 4 Answers
Hi yes there is a keyboard replacement for this model i can get you one i have a computer repair shop but what it seems to me is that you just have a loose connection under th keyboard where it connects to the main board. I can help with this its most likely a loose connection. if you try to re seat the connection and it still does not work i can order you a new keyboard let me know thank you
Posted on Oct 01, 2007
SOURCE:
Why doesnt the third row of keys on my keyboard do not workk
The keyboard itself is defective. The keys are "strung" together in groupings. The T just happens to be on another string then the top row.. To verify you can easly hook up an external keyboard and verify that it works. Once verified it all works then the problem itself will be in the keyboard. Replace the keyboard. You can easly find them online and are not that expensive or hard to replace.
May 15, 2014 | HEWLETT-PACKARD ProBook 6460B
Need to replace keyboard for Balance CN 6555 laptop
Hi travis,
Have you thought about adding an external USB Keyboard ?
If you can give me some measurements Width-height, i can try and track one down for you. Or at least a compatable match.
Whats actually wrong with it, can it be repaired or refurbished ?
Mike @ Compurepair.
Feb 22, 2008 | Balance CN6555 Notebook
Keyboard is stuck for the numbers - i get the notations associated with shift plus number is! instead of 1
Go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem.
Jan 17, 2010 | Balance CN6555 Notebook
Shift key has to be pressed firmly to work.
If there were more that one key that has failed it would indicate that you have a keyboard controller chip that has failed or that the connector from the keyboard to the motherboard is not making proper contact. You may get that key to work by pressing that key very firmly.
You may be able to fix the faulty key by removing that key and spraying the faulty key contact with electronic spray cleaner whilst pressing the key pad several times. It may not work because it may be sealed and the cleaning fluid may not be able to penetrate the key contacts.
Then the only thing to do is to buy and fit a new keyboard from the manufacrurer.,
Nov 26, 2008 | Balance CN6555 Notebook
Need video driver for 557s cn6555 balance laptop
check this link
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=479&CategoryID=3&DetailName=Driver&MenuID=1&LanID=0
Is the original driver, but may be you prefer to download the latest driver from SiS (www.sis.com), this driver is better but the function to interchange between LCD and CRT is lost with this driver.
Sep 12, 2008 | Balance CN6555 Notebook
Keyboard keys refuse to work
Generally when a row goes out the keyboard is shot and needs replaced. How did you rule out hardware issue?
Jul 24, 2008 | HP Pavilion N5150 Notebook
Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Apr 04, 2008 | Balance CN6555 Notebook
Keyboard space bar key does not work. Notebook PC is in Bulgaria. Can I get a replacement keyboard sent to me in Texas so I can send it to my son-in-law? He knows how to swap it out. Daniel210 587-7885
this keyboard space bar will work if you open it and get it detached from the notebook...this process is given in the helpbook with that notebook.....
well if you want to change it then tell me it's name then i will be able to tell you that is this replace able or not?
also tell me the model of the notebook will all it's details and the serial number if that keyboard of that notebook...
thanks..
Nov 28, 2007 | Balance CN6555 Notebook
Balance CN6555 Notebook Logo
59 people viewed this question
Top Balance Computers & Internet Experts
Jaime Hernandez
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
