Question about Panasonic KX-FL511 Plain Paper Laser Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
Hello, everytime a fax comes, it comes with black lines, epcially on the right side of the paper, we cant red nothing. Ink toner usually lasts 2-3 months, this time its over in 3 weeks. anyone can help me ? what do u think the problem may be and how can i solve it ?
    Problem Solver:
  • 9 Answers
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Posted on Dec 30, 2007
SOURCE:
I HAVE BLACK LINES DOWN EACH SIDE OF MY FAXES THAT I DONT KNOW HOW TO GET RID OF
If they are on the faxes that you send you need to clean the reading glass; open the cover where you place your originals when faxing and look in there and there is a thin glass that runs left to right. Clean the glass with a lint free cloth and glass cleaner with out ammonia or some rubbing alcohol.
If the lines are on your incoming faxes it is most likely from your drum. Replace your drum and that will most likely correct the problem.
Jan 14, 2011 | OKIFAX 5650 Plain Paper LED Fax
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I have an hp kx-fl511 fax machine. Has new toner
Hi!
Try to reset advanced features to their default settings
RESET=NO [±]
To reset the advanced features:
1. Press {MENU}.
2. Press {#}, then {8}{0}.
3. Press {A} or {B} repeatedly to select “YES”.
4. Press {SET}.
5. Press {SET} again.
6. Press {MENU}.
Thanks
Rylee
Mar 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black line
Probaby an LED segment is burned out in the scanner assembly.
Dec 22, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
May 21, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
268 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
