Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
Where to find capacitor
Hi, I have the Sceptre monitor with the same problem - power light on but display black. Where do I purchase replacement capacitors? When I get them, do i just clip out the old ones and solder the new ones in place? Thanks - sorry if these are obvious questions.
  • 1 more comment
  • pdxamy Oct 01, 2007
    Thank you. One last issue - I've removed all of the screws from the back and can't seem to disassemble the unit to access board. Any tips?
    OK, I found another post suggesting sliding a card down the side of the unit. That worked to disengage clips around back panel.
    Now, I'm looking at the boards and the capacitors all look OK. I have nothing to lose at this point but can you help me find the ones you are talking about?
    Thank you in advance,
    Amy
  • pdxamy Oct 04, 2007
    When we hook the monitor up, the computer recognizes it but there is no picture. The power light is the only sign of life. Other monitors work fine with the machine.
    Assuming it is the power supply, would a picture of that board be helpful? I will need to remove it to access solder points but don't want to replace all caps...
    Thank you for your help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
Where to find capacitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
Can you shine a flashlight into you display screen with it it connected to your PC and Windows booted. When you do see if you can see the desktop with all your icons in the background if so it is not your Caps..but it most likely is the cold cathode florescent lamp needs replaced this provides backlighting
Posted on Oct 10, 2007
    Genius:
  • 1,153 Answers
Www.bluestar-online.com, mcmelectronics, tritronics etc. You will need to heat up the soldering trace, or legs of capacitor and pullout gently.
Posted on Oct 01, 2007
  • Lashawn Robinson Oct 03, 2007
    One thing two remember is when your monitor was plugged in, did you get OSD, which is on-screen display? That mean if you pressed the other buttons on the monitor like brightness, or adjustments of any kind, did the screen show this. Because its very important if so. If you have OSD, then the problems will be on the video board, if you don't have anything light up then its in the powersupply. These boards are seperated. If on the video board these are small capacitors (SMD) the other way its the large caps in PS.
  • Lashawn Robinson Oct 06, 2007
    I would suggest that you take a picture, but just note that you will have to remove the PS before you can actually work on it.
When I turn it on the monitor display for two seconds and then go BLACK.
See SCEPTRE albums and other as weel for example of failed monitors.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 01, 2010 | Sceptre Computers & Internet
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
My Sceptre x20wg has gone blank. The blue light is on and "clicks" every couple of seconds. There is no display
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre and all monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Aug 16, 2010 | Sceptre X20WC (Black) LCD Monitor
X9G NAGAIV goes black; can display, but wont.
Took it apart, all the way down to the boards and first examined the capacitors on the power board7d50dd4.jpg. It turns out it was a cracked metallized polyester film cap (C10), not a blown electrolytic capacitor. Ordered a new one and some transitors from DigiKey. Dont know if that is the complete fix, but the cracked cap certainly isnt supposed to be there.
Nov 10, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre LCD - no display
It may be the capacitors, since capacitors run about $1.50 or so depending on size you may spend a little over $6 total if you already have soldering equipment or a friend with skills.
Feb 27, 2009 | Computers & Internet
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Sceptre X20G Naga II 20.1" Widescreen monitor
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Oct 22, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Help! Any assistance or advice would be very much appreciated. I have a Sharp LL T19D1-B LCD Minitor purchased a little over 3 years ago. I had a mac plugged into one analogue input of monitor, screen...
This is the power supply inside the monitor itself. It is board that has three capacitors and they are blown out. It is a very inexpensive fix, if you are good with a soldering iron, if not let mw know and I will direct you to a company that can take care of this, for usually $30.00
Sep 26, 2008 | Sharp Computers & Internet
Monitor Powers off after a second or two.........
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
There is 2 caps in the power supply that are blown I have fixed 15 of these LCD with the same problem.
Mar 10, 2006 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
162 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
