Question about Aiwa AV-D55
Low Volume From Left Front Speaker
I have limited volume from my front left speaker. Tried both the "A" & "B" connections, plus a different speaker. Even set at the max. volume level, it is barely audible. Anything else I can try, short of taking it to a shop? Thanks.
4 Suggested Answers
  • 1070 Answers
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
Posted on Apr 26, 2007
i have seen a lot of people with this problem on this receiver... it is really bad quality i guess :(
Sorry can't help.
Posted on Jan 14, 2008
  • 979 Answers
SOURCE: speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Posted on Jun 10, 2008
SOURCE: No surround sound with dolby
I have the same system, the ports for surround speakers only seem to work with the actual surround speakers I bought mine with. I did try to change them but found a sound issue. Looking to buy a new 5 cd changer as mine was damaged during our recent move. Looking to buy model number DX-Z9400M
Posted on Oct 07, 2008
0 characters
1 Points
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Jul 20, 2012 | Yamaha RX-V530 Receiver
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
No music coming from my left front speaker. I ran the level calibration and I can hear the pink noise coming loud and clear to that speaker. I have both front speakers set to the same level, but I only...
Looks like your volume control switch is not working on the left side, you can check it by tapping the knob on the volume control and sound will come out on left side.
The only way to get the sound again is to replace the volume control or pull out the volume control and open it up to clean the contacts in it.
Hope that helps you out!
Thanks for using Fixya!
Dec 12, 2010 | Onkyo TX-DS787 Receiver
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Feb 18, 2009 | Harman Kardon AVR 7200 Receiver
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Aiwa AV-D55 Logo
63 people viewed this question
Top Aiwa Audio & Video Receivers Experts
Michael Thomas
Michael Thomas
Level 1 Expert
Are you an Aiwa Audio and Video Receiver Expert? Answer questions, earn points and help others
