Question about HP iPAQ HX4700 Pocket PC
Suddenly, can't sync PDA
When I sync, I get: "Resolve items for Calendar, Contacts & Tasks." When I click on "Resolve Items" I get: "Items of 1 or more inf types cannot be synchronized. Disconnect and reconnect your device." This doesn't help. Worked last night when I put it away. Nothing wrong with laptop (server). All I did today was add 2 email addresses and 1 phone number as I recall. What should I do? HP 4700 Sony Vaio PC with XP Pro
  • 363 Answers
Re: Suddenly, can't sync PDA
When duplicate items are resolved, are they normally dealt with automatically? If so then you could try to do this manually to get an idea of what the problem is.
Posted on Oct 02, 2007
0 characters
3 Points
Active Sync Installation not recognizing Outlook on PDA
Remove the Activesync software...reinstall it.
Thats the best and fastest suggestion I can give you.
I have the same problem off and on.
Nov 21, 2007 | HP iPAQ rx5915
New sudden sync problem PDA with laptop.
got start> programs > active sync> open> then connect the usb cable...after phone is detected try to do sync. reinstall active sync can also help.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
Treo 650 Sync w/ Outlook 2003
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Sep 19, 2005 | Palm Treo 650 Handheld
How do I fix my Outlook Calendar synchronization problem?
Palm tech fixed my problem. It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive. More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
Sep 13, 2005 | Palm LifeDrive Handheld
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Cannot sync outlook calendar
1) Only one username to use. 2) Not sure about this one. It was working fine exactly as I have it setup now. The only thing that changed is I reinstalled the software, did a hard reset and setup a profile.
Sep 11, 2005 | Palm IIIc Handheld
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
71 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
