Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture please help, we have the tv hooked up to a cable box and it is a black picture with thousands of bright green horizontal lines, i think i screwed up the atennea hookup and i just screwed all the original setting up we have sound though, help please, allison
  • DONANDMAR Jan 08, 2008
    Same problem. Teal screen no picture with thousands of small horizontal lines.
Same problem, worked fine this morning and then tonight I million green horizontal bars - sound is fine. I think from reading up on this we are doomed. I am so pissed, the TV is not even 2 years old.
Posted on Jan 09, 2008
SOURCE:
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
Green Horizontal lines on screen comes and goes RCA L32HD31
I think some problem in the IC of hori./ vertical.circuit.This could fixed in service center
Aug 01, 2017 | RCA Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Mitsibishi 50707
Replace vertical output IC and check capacitors in vertical
power supply....requires chassis pull and above average skill....
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
