Question about Frigidaire Affinity ATF7000ES Front Load Washer
Problems with Rubber Door Sill
The rubber sill around my door holds water and then the washer always smells sour. This washer has done this since I have had it. I purchased August 2006.
  • Anonymous Jun 16, 2008
    I have the same problem - any ideas?
I had a service person come out this week and he told me to leave the door open or get a top loader. I am returning it. The smell is horrible.
Posted on Oct 02, 2007
SOURCE:
Zasounussi problems
on all front loaders, the smell comes from not been used every day, #1, and water sit at the bottom of the drum, is always water in the system from the top of the drain hose to the pump, and they, the manufacture recommend that you use some chemical once per month to clean the unit.
this is what I do. get a bucket of water and bleach 3 water 1 part bleach, get a rug that you do not need any more. wet the rug and with your hand open the door and put the rug unter the rubber around the glass door, in other worth's, the rubber that connects the door to the drum bucket rinclos and water and other material stays there, building mildew, would be good to wear a globe, and clean the inside of these rubber real nice, go around several times to make sure you don't miss a spot., the cloth well come out black means it is loaded. then put the rest of the water and bleach in the machine, add 2 caps of bleach in the machine, fill it to hi and let it stay for 1 hour or more in the drum, then have a gentle cycle, these well clean the rest of the unit. one more thing, if you have members of the family that forget coins or papers in they pocket. may have to do more work to clean and drain the unit, just let me know I well help you.
Apr 14, 2014 | Washing Machines
What is the drivers side hinge pillar panel and the drivers side door sill panel
The windshield metal post from the roof to the bottom
of the door sill is called an A -pillar
That is what your door hinges are bolted to
The metal to your right as you enter the vehicle is
called the B-pillar
That is the one with the drivers door catch
The roof down to the door sill on the rear door of a car
or rear window downward is called a C-pillar
You may hear those terms if you watch a NASCAR race
The door sills are the metal sometimes covered with plastic
you swing your feet over to get in at the bottom between A & B
pillar
You may see rubber or some type covering just past the hinges
as you look into the front fenders
Inside next to the driver or passengers feet ,on the inside,
are what is called kick panels,inside sheet metal on A Pillars
Oct 02, 2012 | 2003 GMC Yukon XL
I have a Maytag Model MHWE300VW11, Serial CSW5002000 and the clothes never smell fresh. There is always a mild sour smell. I always wipe out the washer and wipe all around the gasket in the tub and I...
you could look for a build up of muck- old soap powder etc around the main door rubber, there are places where the muck will collect. put your fingers right inside the door rubber as there are gaps that are hidden . this muck builds up and causes a horrible smell
Aug 29, 2010 | Maytag Washing Machines
Water getting in to drivers matsand you can hear water in the drivers sill
Check the sill, there should be drain holes, they may be plugged, use a small wire or coathanger to clear them.
Nov 20, 2009 | 2005 Porsche Cayenne
Smell from washer ,have sanitized but comes back in a day or so.have cleaned filter and wiped the rubber sill around the door enterance.still has smell like cigeretts.
you have a old soap biuld up beteen your tubs and unless you clear that away it will keep comming back
i usually advise getting a box of dish detergent
not soap,,,, dry crystals,,, i cup in an empty load
the crystals were desinged for much hotter water so they woint dislove as rapidly,,, there by become lilltle scrub brushes fro your inner tub
this should help,,, but also cut back on your soap,
check a dry towel, put it in the sink and shakke it
this should help
have a great day
Oct 26, 2009 | Washing Machines
Rear Window failure
3 routes
1. Could be a broken wire from the door to the a-pillar in the rubber boot. remove the rubber boot, and run the wires for a brake in them ( missing the return for the door latch switch ).
2. Problem with the door latch switch, usually the symptom is the door ajar indicator is always on, and dome lamp won't turn off.
3. A broken wire in the driver's side door sill. This is either towards the front, by the hood latch, or towards the back, where the loom routes up the c-pillar. It will be a single wire spliced to 2 other wires, and it looks like hockey tape is used to cover the splice. Might also have signs of water in the door sill channel.
Oct 21, 2009 | 2004 Ford F150
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Smell
this is a common problem with all front loaders. you need to manually clean the boot, rubber seal, with bleach and water but when done with that you need to put 1 1/2 cups of bleach in the soap dispeners, run a hot wash with no clothes after that run another rinse to be sure all the bleach is out of washer. inbetween washes, leave washer door open (best) or cracked if no room to leave it open
Nov 20, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
