Question about Texas Instruments TI-83 Plus Calculator
5 column pixels missing
I did not use my calculator for a while and when I turned it on there are about 5 columns that do not work. When I do the calculation...those 5 column figures are impossible to see. Any advice how to fix this?
  • syp22 Oct 02, 2007
    How can I fix this? I have to admit I did drop my calculator a couple of times...
  • 363 Answers
This sounds very much like the conductive rubber strip that is between the LCD display and PCB is not making contact. This can happen if the calculator has been dropped or bent.
Posted on Oct 02, 2007
  • Martin B
    Martin B Oct 02, 2007
    I am not familiar with this particular calculator but if you have nothing to lose if you ruin it...
    From experience with a casio I suggest first making a note/scan/picture of the button positions as they can fall out.
    Take out the battery(s) and find the correct screwdriver to undo the case screws.
    There may be several plastic catches to ease apart to remove the back.
    If you take your time and tease the case apart as gently as possible then you might not damage it.
    Inside there will be a circuit board with one side toward the keys.
    There may be more screws to remove to expose the LCD
    What you are looking for is a long strip of rubber between the glass of the LCD and the circuit board, it will have microsopic light and dark stripes across it. The light stripes are insulation and the dark are conductive rubber silicon.
    The one in my casio was about the dimensions of a long matchstick.
    This may not be making contact properly either because it is out of alignment or dirty.
    You might be able to reconnect the battery and see if you can get it working while in pieces.
How do you round to 4100 using the nearest hundred
Step 1 - locate the column in question - in this case the hundreds column
Step 2 - look at the column immediately to the right of this column
Step 3 - if this number is 5 or more, add 1 to the hundreds column
Step 4 - if this number is 4 or less, do not add 1 to the hundreds column
Step 5 - set all numbers to the right of the hundreds column to zero
Let me know if you have any questions.
Good luck,
Paul
Mar 23, 2016 | Office Equipment & Supplies
Solve . Round the answers to the nearest hundredth.
You need to post the question.
To round to the nearest hundredth, you find the hundredths column and look to the column immediately to the right. If it is 5 or more, you add one to the hundredths column. Delete all columns to the right of the hundredths column, and you are done.
Good luck,
Paul
Nov 18, 2015 | Office Equipment & Supplies
Round 9756 to the nearest hundredfolds
Step 1 - identify the column in question - in this case the hundreds' column is the second column, in this case the 5
Step 2 - identify the column immediately to the right of the column above - in this case, the tens' column
Step 3 - if this number is 5 or greater, we add 1 to the column in question - in this case, we add 1 to the hundreds column, making it a 6
Step 4 - if this number is 4 or less, don't add 1 to the column in question
Step 5 - set all numbers to the right of the column in question to 0
I get 9760.
Good luck.
If you have any questions, let me know.
Paul
Sep 24, 2015 | Office Equipment & Supplies
What is 247,039 rounded to the nearest thousand
Step 1 - identify the thousands column.
Step 2 - look to the number immediately to the right of this column
Step 3 - if 5 or over, add 1 to the thousands column
Step 4 - if 4 or less, don't add 1 to the thousands column.
Step 5 - set all numbers to the right of the thousands column to 0.
In this case, the thousands column is the 7. The number immediately to the right is 0, so we don't add 1 to the 7. We set all numbers to the right of the 7 to 0.
I get 247,000
Good luck.
Paul
Aug 26, 2015 | Office Equipment & Supplies
How do I fix the missing left side of my TI-84?
Try squeezing the left side. It that does not work, the calculator may be defective.
Apr 25, 2014 | Texas Instruments TI-84 Plus Silver...
My TI83 screen is not functioning correctly. some lines do not read numbers when I press them in
Do you mean that some of the pixel columns don't work? As in "empty pixels"? If so, I don't think there is a way to solve this problem, and you can either deal with it or buy a new calculator
May 07, 2009 | Texas Instruments TI-83 Plus Calculator
Characters & menus display incorrectly
It is a display driver issue. You can buy a new one or get it repaired ($100).
Feb 10, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-83 Plus Calculator Logo
609 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
