Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Channel changing by itself.
I have a Westinghouse 32 inch LCD. On the local feed of Fox, the channel will change by itself from 18.1 to 18.3 which is the local weather radar. I notice this mostly or exclusively happens during commercials. I have edited 18.3 out of my active channels, but when this happens it comes right back. This is unbelievably annoying. Has anyone else had this issue? Is this something the local Fox channel is doing? Could it be the TV? I do not have this issue on my other HD tv that gets its OTA signal from my DISH receiver. I purchased the TV from best buy over 2 weeks ago and need to decide what to do.
  • Jellybellyma Oct 03, 2008
    My issue is the same, only it changes to channel 7.3 (an NBC channel). The channel changing isn't random, it changes at the end of every show. If the show is 1/2 hr long, it changes exactly at the end, same with 1 hr long shows, right at the mark of the hour, which is what's really got me boggled.
  • Anonymous Feb 13, 2009
    same exact problem, changes at almost the end of a program from 2.1 to 2.3 - we also tried to delete channel 2.3 from the list but it came back on by itself. It also changes when you initially put on that channel - i just have the remote ready to change it back right away again.
I will tell you that westinghouse is the worst company among other brands. If you have warranty, return it and buy a sony or panasonic with a little extra money. It will help you later from buying another TV that is also as crappy as westinghouse's.
Posted on Oct 09, 2007
SOURCE:
Will not pick up FOX channel!
if you did get the channel you should be able to add in a digital amp (25db gain) and pull that channel back in
Jul 10, 2009 | Olevia LT32HVM 32 in. LCD Television
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
How do I change the channel on my Westinhouse LTV32w1?
I found my owner's manual and it provided me with the directions to change the channel to 3 (the setting to receive the signal). Problem solved.
Jun 26, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
My tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
731 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
