Question about Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 It keeps saying to close the back cover, however, i dont no what the back cover is and i think it is closed. no one opened it that i know of. please help
  • 2 more comments
  • mrosanally Aug 01, 2008
    It tell me to close the back cover
  • fmc-jw Aug 11, 2008
    The display reads "back door open, close back door" There is no back door open and it never has been but I keep getting this message. I think it all started when we had a power outage and the machine was on.
  • profjake Oct 17, 2008
    In many cases, the little lever has just come out of the hole and slightly displaced to the left. I noticed that the plastic part of the horizontal rod it was connected to, was bowed a bit. I carefully pushed the rod to the right and got the small plastic lever to go down into the slot and got it working again.
  • Anonymous May 21, 2009
    PROBLEM: During printing, suddenly the message "Back Flap Open" started to flash and the printer stopped working.
    THE DISCOVERED SOLUTION: I flipped the rear panel open using the thumb space indentation provided on it. Inside, the flap came open and would not close. Looking again, I found that paper had jammed and fan folded along the pich where the roller and the drum press against each other. Using a pair of long nose pliers, I pulled the fan folded paper out. There were no other visible obstructions, so I tried to close the rear flap. It closed. I then closed the rear panel. It closed as well. I then turned the printer on. The error message was gone. The printer worked fine after that.
Props to Profjake. I followed his advice and problem solved! Here is what I found out.
I had the "Back door open" error on the LCD panel. There is a "interupter" type of sensor that detects if the back door is open or closed. When the back door is closed a lever is pushed forward and blocks the interupt module. The lever that blocks the sensor was not reqching the sensor horizontally - it was too far to the left. The lever on the far right is part of a 6" rod that goes across the middle of the paper path. The rod had jumped out of it's "home" position to the left and it was bowed a little bit. I carefully re-seated the rod to by gently lifting it and moving it to the right into a slot 1/8" from where I found it. The error cleared immediately. The was most likely caused by removing a paper jam.
Once again props to Profjake as his advice led me to the solution.
Hu said that!
Posted on Jun 17, 2009
OCTOBER 31, 2008..I HAD THE SAME PROBLEM AND DIDN'T HAVE A SOLUTION..EVERYONE IS RIGHT ON THIS WEBSITE..IT SEEMS THE BAR IN THE BACK THAT SHOWS HOW TO TAKE OUT THE JAMMED PAPER HAS A LITTLE ROD THAT FITS IN A BLANK SPACE TO THE RIGHT. IF IT IS OUT OF PLACE, THE CLOSE THE BACK COVER NOTICE COMES ON..IT IS NOT HARD TO FIX AND YOU DON'T EVEN GET DIRTY HANDS..
Posted on Oct 31, 2008
  • 3 Answers
When you open the back cover, you will see a flap that will come open As you are looking at this open flap, look to the far right and you will see a small lever that is of a slightly different color. This lever operates a small switch that tells the printer that the cover is closed. If you lift up slowly on the open flap, you will hear the lever activate this switch (in a working model, of course) and turn off the "open cover" message. If you do not hear the click, check to see if that small lever is missing. If the lever is not broken off or you do not hear the click, the switch has failed. You can bypass the switch if it has failed but requires some disassembly. Test the switch with a multimeter for proper operation before blaming the switch. If you bypass the switch and the "open cover" message is still on then the logic board may have failed. If the lever is missing, you will have to jam a folded piece of paper in there to see if the switch works. Replace the plastic lever, if broken, the switch, if bypassing it worked, or the logic board, as appropriate if the lever and switch are functioning. You may run the printer with a bypassed switch or replace the broken parts. This requires some degree of mechanical skills in knowing how to disassemble and reassemble your printer safely. If it is beyond your capability, you may have to let someone else do it or take it to a repair shop.
Posted on Oct 04, 2007
Thank you cyborgdale, your solution helped.
Posted on May 02, 2008
I checked for a paper jam and I found one page. I took this and my printer started working
Posted on Jan 29, 2008
I've just been fighting with the 'close the back cover' problem too. All the turning 'OFF' & 'ON' didn't work or opening & closing of covers didn't work. For all that I could see, all jammed paper was gone.
It wasn't until I took our the toner cartridge that I saw one last piece of shredded paper still stuck in there. When I took it out, everything finally worked.
Posted on Nov 13, 2007
If you've had a paper jam and getting "close back door" message, make sure to open the back door to check for a paper jam (in my case one page was accordioned-up tight against the drum unit).  This solved it for me.
Posted on Oct 19, 2007
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Says back cover is open when door is closed.
Hello. Unplug the printer. Leave it unplugged for two full minutes. Plug it in, opoen the back cover and forcefully shut it.
This should solve your problem. J.
Aug 17, 2010 | Brother DCP-7020 Black and White Copier
My Brother DCP 7020 won't stop flashing close back door
There's a micro-switch that "trips" when the door is opened/closed. It's not sending a "closed" signal to the printer. Clean the switch, with a blast of compressed air. Check that a small "finger" is going-in to the slot, to "trip" the sensor, as the door is closing.
May 07, 2010 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Help
one ot the doors, most likely the one on the right is not closed, there is a sensor switch there it is not being activated, make sure all levers are in he correct positions so the doors can close evenly.
Jul 23, 2008 | Brother DCP 7010 Multifunction Laser...
Brother printer
One of 2 things has happened.
There are 2 types of switches used as interlock witches on those covers.
Mechanical switches, where there would be a small opening in the frame where the cover is. It may have fallen out of the snaps of more then likely the tab that actuates the switch has broken off. look carefully with that cover open and see if a tab is broken.
You can cheat it with some not conductive item put into that opening to actuate the switch and tape over it. Then order a new cover, That's the most likely.
There are also magnetic switches used in some covers and possibly the magnet has fallen off not actuatinng the switch.
Once you locate the switch you will locate your problem.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
The printer jammed and now will not restart
unit was turned off while it had this error, follow these instructions:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=dcp7020_us&Cat=4
Dec 03, 2007 | Brother DCP-7020 All-In-One Laser Printer
Back cover error on LCD won't go away
This is most likely caused by the back cover switch. It is either broken or the lever on the back cover is broken off.
Sep 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
1,306 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
