Question about Mitsubishi VS-50502 50" Rear Projection Television
Mitsubishi 50 in vs-5043
I have a mitsubishi vs-5043 and cannot alight the red with the blue and green crosshairs in both alignment settings and do not know how to fix it
  • Anonymous Jan 09, 2008
    which convergence ic's does this model need(vs-50502)
    Genius:
  • 1,694 Answers
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Posted on Oct 05, 2007
Mitsubishi VS5043 convergence will not align
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 22, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Manual for mitsubishi vs 5043 cannot program for
If you go into the main menue with the Mitsubishi remote, there should be a set up icon for programing stations. It should give you a selection for cable and or standard tuning. Select cable then press auto program.
Hope this got it done,
Skyassoc
Jun 19, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Convergence problem
I have a VS-45607 and If the VS-5052 has the same menus then there are two options for convergence. One is the basic convergence where there is one set of crosshairs and you line them up. Then there should be an option for "advanced" calibration where the whole screen looks like a grid and you go to un-converged crosshairs and align the screen. Most likely not all of them will need to be adjusted, but for me, the lower right hand corner wasn't aligned right and this cleared it right up.Good luck
Dec 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs 5043 no picture
have the tubes checked out you may have a loose connection
Jul 15, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-5043
Look for short on Green CRT board.
Aug 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
