Question about Mitsubishi WS-55807 TV
How to remove problem?
There is power.
  • 59 Answers
What is the problem
Posted on Oct 31, 2007
SOURCE:
HOW DO I REPLACE THE HIGH PRESSURE LINE FOR A POWER STEERING UNIT ON A 1998 MUSTANG?
Disconnect battery ground cable.
Remove engine Air Cleaner (ACL) .
Disconnect electrical connector in back of engine cooling fan motor.
Remove radiator fan shroud.
Disconnect constant control relay module harness from headlamp harness and place constant control relay module on top of engine to provide accessibility to power steering lines.
Remove wiring harness guide retaining screws and position guide aside.
Remove screw at power steering hose bracket.
Remove anti-rattle clip.
Remove plastic strap retaining tubes to power rack and pinion steering gear.
Remove power steering pressure hose at power steering pump.
Remove power steering pressure hose at power rack and pinion steering gear.
Remove power steering pressure hose from vehicle.
Reverse procedure to install new hose.
Fill and bleed power steering system.
Aug 20, 2011 | Ford Mustang Cars & Trucks
I need to find out how to remove the power steering pump on a 2006 pontiac grand prix 3.8L
Power Steering Pump Replacement
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
*This originally came from abauto
Mar 24, 2011 | 2006 Pontiac Grand Prix
How do I get my power steering pump out of 2002 yukon
Hello walker_227,
Removal Procedure:
SPECIAL TOOLS: You will need a power steering pulley remover and installer tool, DO NOT USE A HAMMER.
1. Remove the power steering pulley.
2. Raise the vehicle.
3. Remove the oil pan skid plate from the vehicle, if equipped.
4. Place a drain pan under the vehicle.
5. Remove the power steering pressure hose from the power steering pump from underneath the vehicle.
6. Lower the vehicle.
7. Remove the return hose from the power steering gearbox and the power steering pump.
8. Remove the bolt retaining the rear bracket to the engine.(See picture below)
9. Remove the bolts from the front of the pump.(See picture below)
10. Remove the pump from the vehicle.
11. Remove the bracket from the rear of the pump
Installation Procedure:
1. Reverse above procedure
2.Fill and bleed the power steering system.
Mar 14, 2011 | 2004 GMC Yukon
How to replace a steering rack? do i really have to loosen the bolts to the engine cradle to gain access?
Power Steering Gear Replacement
Removal Procedure
  1. Raise the vehicle on a hoist.
  2. Remove the tires and wheels.
  3. Remove the stabilizer shaft links from the control arms.
  4. Remove the tie rod ends from the steering knuckle.
5. Remove the intermediate shaft lower pinch bolt from the power steering gear.
  1. Remove the stabilizer shaft.
7. Remove the power steering hoses from the from the power steering gear.
8. Remove the power steering gear bolts from the frame.
  1. Remove the power steering gear through the left wheel opening.
Feb 06, 2011 | 2001 Chevrolet Malibu
How do you remove the power steering pump from a 2001 Chev Blazer with the 4.3 engine?
4.2L Engine
  1. Remove the air cleaner assembly.
  2. Remove the drive belt.
  3. Install a drain pan under the vehicle.
  5. Disconnect the power steering cooler hose from the power steering pump.
  6. Disconnect the wiring harness from the wiring loom on the power steering pump.
  7. Remove the power steering pump mounting bolts.
  8. Remove the power steering pump.
  9. Remove the power steering pump pulley.
  10. Remove the power steering pump pulley using Power Steering Pump Pulley Remover tool no. J 25034-C, or equivalent.
Oct 30, 2010 | 1993 Plymouth Acclaim
Cant find were to put powersteering fluid
Power Steering Pump Removal & Installation 3.8L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Place a drain pan under the vehicle.
  3. Remove the accessory drive belt from the power steering pump pulley.
  4. Raise and safely support the vehicle.
  5. Remove the right front tire and wheel assembly.
  6. Remove the hoses from the power steering pump.
  7. Remove the mounting bolts and the power steering pump from the engine.
  8. Remove the reservoir and pulley from the pump if necessary.
To Install:
Power steering pump removal/installation (3.8L engine) gm-08-38-480.gif
  1. If removed, install the power steering pump reservoir and pulley on the power steering pump.
  2. Position the power steering pump to the engine and install the mounting bolts. Tighten the bolts to 25 lb ft (34 Nm).
  3. Install the pressure and return hoses to the pump.
  4. Install the right front tire and wheel assembly.
  5. Lower the vehicle.
  6. Install the accessory drive belt.
  7. Fill and bleed the power steering system.
  8. Inspect the system for leaks.
  9. Remove the drain pan from under the power steering pump area.
3.4L Engine To Remove:
  1. Place a drain pan under the power steering pump.
  2. Remove the coolant reservoir.
  3. Remove the pulley from the power steering pump.
  4. Remove the wiring harness near the power steering pump and place it out of the way.
  5. Disconnect the fluid hoses from the power steering pump.
  6. Remove the mounting bolts from the power steering pump and remove the pump.
To Install:
Power steering pump removal/installation (3.4L engine) 88008g71.gif
  1. Position the power steering pump assembly to the engine and install the mounting bolts. Tighten the mounting bolts to 25 lb ft (34 Nm).
  2. Install the wiring harness in its original position.
  3. Install the pulley on the power steering pump.
  4. Install the coolant reservoir.
  5. Fill and bleed the power steering system.
  6. Inspect the system for leaks.
  7. Remove the drain pan from under the power steering pump.
Sep 18, 2010 | 2000 Chevrolet Impala
Power steering pump, broken, how to replace
Power Steering Pump - REMOVAL & INSTALLATION
3.0L OHV (2 valve) Engine
(see Figures 1 and 2)
Fig. 1: Power steering system-3.0L OHV (2-valve)
Fig. 2: A few special tools are required to remove and install the pulley on the power steering pump
  1. Disconnect the negative battery cable.
  2. Remove the accessory drive belt.
  3. Remove the alternator.
  4. Drain and remove the radiator coolant recovery reservoir.
  5. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  6. Remove the idler pulley from the power steering pump support.
  7. Remove the bracket mounting bolt located under the belt tensioner mounting.
  8. Remove 2 retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  9. Clamp the pump support bracket in a suitable vise.
  10. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the 3 bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To install:
  1. Install the power steering pump to the power steering pump support.
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 17-24 ft. lbs. (23-32 Nm).
  4. Complete the installation by reversing the removal procedure.
  5. Fill the power steering reservoir with power steering fluid.
  6. Connect the negative battery cable.
  7. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Hope this helps.
Sep 06, 2010 | 1996 Ford Taurus
How to change power steering pump on98 windstar with 3.8 engine
3.8L Engine
POWER STEERING PUMP Removal
  1. Remove the battery ground cable.
  1. sww~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY . TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE POSITIVE BATTERY CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY SYSTEM COMPONENTS.
    Disconnect the positive battery cable and wait one minute for backup power supply energy to be depleted.
  1. Remove the drive belt. Remove the generator. Remove the power steering pump pulley as described.
  1. Position the drain pan. Remove the power steering pressure hose and the power steering return hose from the power steering pump .
  1. Remove the idler pulley.
  1. On vehicles equipped with A/C, remove the A/C compressor brace.
  1. Remove three bolts and the power steering pump and bracket assembly.
  1. Remove the retaining bolts and power steering pump from the power steering pump support .
Installation
  1. To install, reverse the removal procedure.
    1. Tighten the power steering pump bolts to 40-55 Nm (30-40 lb-ft).
    1. Tighten the power steering bracket bolts to 40-55 Nm (30-40 lb-ft).
    1. Tighten the A/C compressor brace nut to 20-25 Nm (15-18 lb-ft).
    1. Tighten the idler pulley bolt to 40 Nm (30 lb-ft).
Mar 10, 2010 | 1998 Ford Windstar
Changing power steering pump
Power steering pump special tools
Power Steering Pump Removal & Installation Power Steering Pump (2V) To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the accessory drive belt.
  4. Remove the alternator.
  5. Drain and remove the radiator coolant recovery reservoir.
  6. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  7. Remove the idler pulley from the power steering pump support.
  8. Remove the belt tensioner.
  9. Remove the bracket mounting bolt located under the belt tensioner mounting.
  10. Remove two retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  11. Clamp the pump support bracket in a suitable vise.
  12. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the three bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To Install:
NOTE: The pulley must be installed within 0.010 in (0.25 mm) flush with the power steering pump shaft.
  1. Install the power steering pump to the power steering pump support. Tighten the mounting bolts to 18 ft-lb. (25 Nm).
  3. Install the power steering pump/pump support and torque nuts/bolt to 24 ft. lbs. (33 Nm).
  4. Install the bracket mounting bolt located under the belt tensioner mounting.
  5. Install the belt tensioner.
  6. Install the idler pulley to the power steering pump support.
  7. Connect the hydraulic pressure and return lines.
  8. Install the radiator coolant recovery reservoir.
  9. Install the alternator.
  10. Install the accessory drive belt.
  11. Fill the power steering reservoir with power steering fluid.
  12. Connect the battery ground cable.
  13. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Jun 28, 2009 | 1999 Ford Taurus
Power steering pump
not too hard if you have some tools.
  1. Raise and support the vehicle.
  1. Remove the power steering pump pulley (3A733). Refer to the procedure in this section.
  1. Place a drain pan under the power steering pump (3A674).
  1. Remove the power steering pressure hose bolt from the power steering pump. Place the power steering pressure hose (3A719) up and out of the way.
  2. Remove the two power steering reservoir pump hose bolts. Place the power steering reservoir pump hose up and out of the way.
  3. Remove the three front power steering pump bolts.
    1. Remove the rear power steering pump bolt.
    1. Remove the power steering pump from the vehicle.
Aug 21, 2008 | 1998 Mercury Villager
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
