Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
Black screen after 1/2 second power-up of Sony SDM-HS73
By JerryD on Oct 01, 2007
My grandaughter has a black screen and green power light within about 1/2 second of powering on the SDM-HS73 monitor. She had a green screen with a loose cable to he PC and she tightened and checked cables. I also checked the cable and disconected power tro the monitor for 20 seconds. Picture is good for a moment whenever power is toggled. Monitor is about 4 to 5 years old.
I checked screen saver (10 minutes and set for pipes). I updated default driver from CD. No luck. Did see a waiting icon for a moment when screen saver would have displayed and scrren saver was there on power toggle wiew (the viewing moment). Ran anti-virus also. Nothing bad is obvious at the PC. It seems to be a problem in the monitor itself, such as power save kicking in immediately.
Comments:
Oct 06, 2007
- Thanks Bratty. I assume you mean the monitor power supply. I will open it and check the capacitor.
JerryD
Same Problem
Apr 04, 2008
-   where and how much can i find the capacitor and bingo for this monitor? i have a person who can do it, but hes busy right now and doesn't have time to find the parts. someone tell me where i can get them, how much there are, and how many i would need for this monitor. the monitor is a sony sdm-hs730. thanks-   norco125
Jan 05, 2008
-   I have a similar problem as JerryD. My monitor is 3 and 1/2 years old with less than 1500 hours in use. Starting a couple of days ago my monitor when switched on does power on with green light staying, however it will show only a moment (maybe 1/10th of a second) of image on the screen. If it is not connected to a pc and it is switch on then the image that will show is kind of short red, green and maybe yellow lines appearing on the screen but only for about 1/10th of a second. I have tried Sony's recommendation and of course that does not fix it. All connections appear okay. Nothing that maybe overheating can be sensed. Does anyone out there have any solution? Help and thanks. NestorFMF-   NestorFMF
Dec 18, 2007
-   I have the same problem, Bratty, do you have any pics on which one it is?
Thanks,
Jake
-   nutt318
Solution #1
posted on Dec 18, 2007
Somewhat Helpful)
nutt318
Rank: Apprentice
Rating: 76%, 2 votes
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 06, 2009
Not Rated)
gvblairj
Rank: Apprentice
Rating: 75%, 1 votes
what if all the caps appear to be goo, no leak, no swelling?
Was this helpful?
Yes
No
Solution #3
posted on Feb 25, 2009
Not Rated)
xxdarkchild
Rank: Guru
Rating: 89%, 31 votes
even after you replace the cap it still wont be fixed because the bad cap overpower the to transistors these also need to be replaced the number is something like c7506 they wont take more power for long so these will most likely all so be bad depending on manifacture date the transister part numbers do change.but are close to that. I repair these lcd problems alot in my computer shop.
Was this helpful?
Yes
No
Solution #4
posted on Oct 06, 2007
Not Rated)
bratty
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, it was the capacitor in my power supply. Replaced the bulging capacitor and bingo, monitor is working great.
Was this helpful?
Yes
No
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SDM-HS73P 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
