Blurry/Hazy picture on Philips Tv
Hi - 2 and a half years ago i bought a Philips 36pw8719 crt from currys. Over the last number of weeks the picture has become blurry/hazy and it seems to be getting worse. Its not that noticeable when there are closeups but any scenes at a distance are not good. Any text that appears on screen is awful though. I have phoned Currys and they have told me that because it is over the year long guarantee period there is not much they can do(typical really). I have seen somewhere else about a G1 intermmitent short problem(no idea what this means). I paid approx £900 for the set in the UK here. Any ideas?
  • Anonymous Sep 08, 2008
    philips 34pw8502/37 is blurry can't read the word
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As your problem is the picture has become blurry/hazy 1 it sounds me that there is a little sparking near high voltage section that is near flyback transformer.please get it check. 2 if it is ok then focusing anode wire going to crt base from flyback transformer is not making proper contact due to some foreign material deposited on it. please call tech person if you ae not aware of it as tv is a very high voltage device.
Posted on Oct 02, 2007
SOURCE:
Sony trinitron tv
Hello!I bought 12 years ago a SONY TV KV-28FX60D with out any technical issue so far.The last couple of days I powered on and after five minutes it starts showing only half of the screen, losing the bottom half of the picture. what do you think it might be. Can you suggest a part to be replaced and if it is worth fixing, cost wise? Thanks KONSTANTINOS
Jan 02, 2014 | Televison & Video
I have sound but no picture. 42" plasma. i bought 4 years ago. last week the botom half of the screen started flashing back and forth between the picture and all black, but we just came home and now it is...
Sounds like you need a lower Y-DRV/BUFFER board (996500032640) and a Y-SUS board (996500032643). Part numbers listed are for models which use a Samsung Panel.
May 10, 2010 | Philips 42PF9630A 42 in. Plasma Television
Hazy crt tv picture for the first 15 minutes after turn on.
yes,, while heating up,, some transisters are failing.. have to check the circuit board,,
Sep 29, 2009 | Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Philips
if you bought it under one year ago then the retailer should be obliged to either replace it or repair it. I would look into this further, ask to speak to the manager or something casue when a tv switches itself off it indicates an error inside and turns itself off to prevent further damage.
Jan 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sanyo 32" hdtv
CRT socket is the the problem of your tv,so change the socket.it is a white plastic with a 7 or 9 pins that attach to the picture tube
Jul 12, 2008 | Sanyo HT32744 32" TV
Grundig T55-1010
Hi.
This isnt a simple fix for someone not used to electronics but here it is.
CONNECT A 390OHM RESISTOR BETWEEN W129 (GROUND) AND PIN 56 OF THE MICRO, PRESS BUTTON 7 ON THE REMOTE FOR A MINIMUM OF 6 SECS.
http://dysonmanuals.inc.io/
chris..
Dec 07, 2007 | Televison & Video
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Jan 02, 2007 | Philips 36PW9525C 36" TV
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
May 18, 2006 | Grundig GF70-600 TV
Televison & Video Logo
951 people viewed this question
Top Televison & Video Experts
Ekse
