Question about Nintendo Wii Console
Unable to read wii discs
My wii has an error which say unable to read disc, it also makes a strange noise when its trying to read the disc, any help would be greatful
  • Anonymous Jan 14, 2008
    Same problem - trouble shooting says make sure discs are clean and inserted the correct way up - they are!!.
    Held on for 20 minutes to the nintendo wii helpline this morning and still didnt get put through to anyone - have emailed instead.
  • Natalie
    Natalie Jan 09, 2014
    my wii doing the same
Call nintendo and replace it !
Posted on Jan 17, 2008
    Problem Solver:
  • 16 Answers
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Posted on Oct 04, 2007
    Problem Solver:
  • 7 Answers
Did you put it the wrong way. just try the other side of the disc
  • 34 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 06, 2009
SOURCE:
Wii unable to read gamecube disc... :(
Mar 23, 2009 | Nintendo Wii Console
Unable to read disc.
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Feb 02, 2009 | Nintendo Wii Console
Will not read wi disc
well you can get a cleaner wii thing cause your wii might have dust in it so you can try that there around $20-$30 each in aus so that should work
Jan 15, 2009 | Nintendo Wii Console
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
Dec 27, 2008 | Nintendo Wii Console
Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 04, 2008 | Nintendo Wii Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
Wii making strange noises and wont start game
Unplug anything you have connected via USB. Try that as it has been a constant issue for many first gen Wii's
Oct 31, 2008 | Nintendo Wii Console
Unable to read disk error
Jul 05, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,164 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
